could really do with your help folks.. ive messaged nhn too but i appreciate he probably has 100's of messages so if anyone has had the same sort of problem and knows what it was and how you fixed it.. im all ears. ive had a look through the forum but just dont seem to be having any luck. checked wiring.. fuses
ive had my car scanned the other day and it came up with quite a few faults (the guy said that the majority of them were to do with the fact the battery had died. he had done a scan and cleared most of them however a few had stayed on - (i will attach the scan that he had sent me)
ORIGINAL SCAN THAT HAD BEEN CARRIED OUT
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 56 76 77
VIN: WAUZZZ8P18A043042 Mileage: 144560km-89825miles
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Sporadic communication error 1000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 T HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0G6FNN0W8
Coding: 01030003180F0060
Shop #: WSC 06314 000 00000
VCID: 43855F6E0220615992-8016
1 Fault Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0�C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0010 0000
Address 03: ABS Brakes Labels: 1K0-614-517-MK60AT.clb
Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD
Component: ESP 4MOTION MK60-AT 0102
Revision: 00H14001
Coding: 0004738
VCID: 69D9ADC640CC5B0978-803C
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0420
Revision: 093439 Serial number: 8P0820043AH
VCID: 72EBCAAA6D1A98D1C9-8026
3 Faults Found:
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:45
Freeze Frame:
ON
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:15
Freeze Frame:
Temperature: 7.5�C
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 116961 km
Time Indication: 0
Date: 2015.03.18
Time: 05:24:20
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007403389
Coding: 018C0F07A0141000470000000000000000085E175C010000000000000000
Shop #: WSC 06435 000 08192
VCID: 458141760C145F69BC-8010
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00055568
Shop #: WSC 06435
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 17
Reset counter: 189
Mileage: 142752 km
Time Indication: 0
Date: 2016.11.19
Time: 19:49:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:00
Freeze Frame:
ON
Voltage: 14.50 V
ON
ON
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 189
Mileage: 144419 km
Time Indication: 0
Date: 2017.01.08
Time: 09:49:00
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
OFF
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CR0002HP0
Coding: 0071612
VCID: 4D917956D464A72974-8018
Subsystem 1 - Serial number: 63328RB402BAA41AQ
Subsystem 2 - Serial number: 63428RB402B7EDB71
Subsystem 3 - Serial number: 63528RB402BAA3C1T
Subsystem 4 - Serial number: 63628RB402B7EE0D%
Subsystem 5 - Serial number: 63747RB402610AF5M
Subsystem 6 - Serial number: 63847RB402610AD4K
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
VCID: 41895566183C734980-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
2 Faults Found:
01303 - Unlicensed Version. Not all DTCs
004 - will be decoded. - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 M HW: 8P0 920 981 M
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 2246G001001162
Coding: 0005428
Shop #: WSC 00783 067 57207
VCID: 428B5A6A1D3A685199-8016
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K0771882BA
Coding: E9821F0E4006020101
VCID: 306F00A2A396EAC17F-8064
7 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 40
Mileage: 139252 km
Time Indication: 0
Date: 2016.08.06
Time: 08:34:03
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 184
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 00:00:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:02
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
01324 - Control Module for All Wheel Drive (J492)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 366336BA41F2C4F125-8062
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0G6FNN0W8
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
Component: RNS-E HIGH EU H74 0600
Revision: 04S Serial number: AUZBZ7G0911500
Coding: 0209717
Shop #: WSC 00441 210 91426
VCID: 387F38824BE6328137-806C
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 190
Mileage: 98321 km
Time Indication: 0
Date: 2013.07.17
Time: 19:35:30
Freeze Frame:
Voltage: 10.60 V
Mileage: 144560 km
Count: 1601
Clock: 17:01
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 5
Reset counter: 184
Mileage: 143259 km
Time Indication: 0
Date: 2016.12.03
Time: 21:26:28
Freeze Frame:
Mileage: 144460 km
Count: 1301
Clock: 00:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 190
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 01:36:56
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0060
Coding: 0000560
Shop #: WSC 00441 210 88110
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H10 0080
Coding: 1880202002186D298505489AC637
Subsystem 1 - Part No: 8P0 959 433 J
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 3 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 4 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000560
VCID: 44875C72072E6661AB-8010
1 Fault Found:
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209717
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 190
Mileage: 98321 km
Time Indication: 0
Date: 2013.07.17
Time: 19:35:30
Freeze Frame:
Voltage: 10.60 V
Mileage: 144560 km
Count: 1601
Clock: 17:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 184
Mileage: 143259 km
Time Indication: 0
Date: 2016.12.03
Time: 21:26:28
Freeze Frame:
Mileage: 144460 km
Count: 1301
Clock: 00:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 190
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 01:36:56
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0070
Revision: 00H09000 Serial number: 00067824830720
Coding: 0000113
Shop #: WSC 131071 1023 2097151
VCID: 3C7724927FDE1EA1D3-8068
1 Fault Found:
01543 - Parking Aid Warning Chime (H15)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:14:46
Address 77: Telephone Labels:
VCID: 55A19136BCB4EFE9CC-8000
End-------------------------(Elapsed Time: 05:40)--------------------------
Address 01: DTCs cleared
Address 08: DTCs cleared
Address 16: DTCs cleared
The ones that have stayed on are to do with faults that i know about
the faults i know about are my "mode" and "voice" button on my mfws do not work anymore and also that i cannot seem to connect my phone to the bluetooth
i have now purchased myself a vcds hex v2 and carried out a scan on my car now and the only one that is staying on is this
Coding: 0004012
VCID: 41DC4FB3CD8528CF62D-8014
1 Fault Found:
but my phone still does not connect and also i noticed it took a very long time to scan whilst it was on "77 telephone and it ended up freezing so had to come out of it
can you please help me with
1. why it wont scan on the telephone
2. is it my voice recognition module that is broken which is why i cant coonnect my phone to bluetooth and if so where abouts is the location of module for voice recognition
originallly it was my drivers dooor that i was trying to sort out as it would not lock with key fob. long story shorter ha. i got a 2nd hand door lock mechanicsm, still wasnt working, found 2 broken wires and repaired and that fixed it but noticed the day afetr that the battery was flat and that the button on the side of my door card (like a motion sensor for leaving doogs in the car when the door is locked for the alarm) that it wasnt working when i pressed the button and my interior light was not coming on when i opened the door and it was not showing on the dis that the door was open too.
if you have any ideas what that could be.. im swaying towards a dodgy microswitch in the door lock mechanism as i put the old locking mechanism on today and the switch seemed to work ok.
THIS IS THE NEW SCAN THAT I DID TODAY
VIN: WAUZZZ8P18A043042 Mileage: 144570km-89831miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
VCID: 43D045BBD7993ADF701-8016
Readiness: 0110 0001
Revision: 00H14001
Coding: 0004738
VCID: 698CB7139575008F9AD-803C
VCID: 72BED07FB8A3C3572B7-8026
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 116961 km
Time Indication: 0
Date: 2015.03.18
Time: 05:24:20
Freeze Frame:
ON
Coding: 818C0F27A0141000470000000000000000095E175C010000000000000000
Shop #: WSC 12345 123 00000
VCID: 45D45BA3D9AD04EF5E5-8010
Coding: 00055568
Shop #: WSC 12345
Coding: 0071612
VCID: 4DC4638301DDFCAF965-8018
Coding: 0004012
1 Fault Found:
Coding: 0005428
VCID: 42DE40BFC88333D77B7-8016
VCID: 303A1A77762FB1479D3-8064
Coding: 0000001
VCID: 36362C6F944B9F77C7F-8062
Coding: 0209717
VCID: 382A22579E5F6907D53-806C
Coding: 0000560
Subsystem 1 - Part No: 1K0 951 605 C
Subsystem 2 - Part No: 1K0 907 719 C
Subsystem 3 - Part No: 8P0 951 177
Coding: 0000560
VCID: 44D246A7D2973DE749B-8010
Coding: 0209717
Coding: 0000113
VCID: 3C223E47AA67452731B-8068
VCID: 55F48BE32D0DB46F2E5-8000
End----------(Elapsed Time: 13:18, VBatt start/end: 11.7V/11.7V)-----------
SO SORRY FOR THE LONG MESSAGE AND RAMBLING ON BUT I WOUKLD REALLY APPRECIATE IT IF YOU COULD SHED SOME LIGHT ON HOW TO GO AROUND FIXING IT
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Revision: 00H14001
Coding: 0004738
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:45
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:15
Freeze Frame:
Temperature: 7.5�C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 116961 km
Time Indication: 0
Date: 2015.03.18
Time: 05:24:20
Freeze Frame:
ON
Coding: 00055568
Shop #: WSC 06435
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 17
Reset counter: 189
Mileage: 142752 km
Time Indication: 0
Date: 2016.11.19
Time: 19:49:00
Freeze Frame:
ON
Voltage: 14.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:00
Freeze Frame:
ON
Voltage: 14.50 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 189
Mileage: 144419 km
Time Indication: 0
Date: 2017.01.08
Time: 09:49:00
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
OFF
OFF
OFF
OFF
Coding: 0071612
Coding: 0004012
2 Faults Found:
Coding: 0005428
7 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Reset counter: 40
Mileage: 139252 km
Time Indication: 0
Date: 2016.08.06
Time: 08:34:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 184
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 00:00:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:08:57
Coding: 0000001
Coding: 0209717
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 190
Mileage: 98321 km
Time Indication: 0
Date: 2013.07.17
Time: 19:35:30
Freeze Frame:
Voltage: 10.60 V
Mileage: 144560 km
Count: 1601
Clock: 17:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 184
Mileage: 143259 km
Time Indication: 0
Date: 2016.12.03
Time: 21:26:28
Freeze Frame:
Mileage: 144460 km
Count: 1301
Clock: 00:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 190
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 01:36:56
Coding: 0000560
1 Fault Found:
No Faults Found
Coding: 0000560
1 Fault Found:
Coding: 0209717
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 190
Mileage: 98321 km
Time Indication: 0
Date: 2013.07.17
Time: 19:35:30
Freeze Frame:
Voltage: 10.60 V
Mileage: 144560 km
Count: 1601
Clock: 17:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 184
Mileage: 143259 km
Time Indication: 0
Date: 2016.12.03
Time: 21:26:28
Freeze Frame:
Mileage: 144460 km
Count: 1301
Clock: 00:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 190
Mileage: 144362 km
Time Indication: 0
Date: 2017.01.07
Time: 01:36:56
Coding: 0000113
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 144468 km
Time Indication: 0
Date: 2017.01.13
Time: 00:14:46
Coding: 0004012
1 Fault Found:
Revision: 00H14001
Coding: 0004738
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 116961 km
Time Indication: 0
Date: 2015.03.18
Time: 05:24:20
Freeze Frame:
ON
Coding: 00055568
Shop #: WSC 12345
Coding: 0071612
Coding: 0004012
1 Fault Found:
Coding: 0005428
Coding: 0000001
Coding: 0209717
Coding: 0000560
Coding: 0000560
Coding: 0209717
Coding: 0000113
