  2. Dismiss Notice
New to RS3 Ownership need Advice on sunroof issue
Sequence Mar 20, 2020
  1. Sequence
    Sequence Member
    65
    37
    Hi Guys,
    Had my 69 plate RS3 for just over a week now before purchase noticed a knock sound from the sunroof when going over bigger bumps or spirited cornering was advised that it was a know issue and just required a thicker grease for the runners well fast forward to today a week and a bit and have had that grease done and the issue is still present and they now want to book me in to look further into it and possibly have all the headlining down ect.
    Not sure how i feel about that...
    Is this a common issue and is it fixable without issues ?
    i feel more issues could be introduced pulling the interior apart like that.
  2. Avatar
    snack-media
    Advertisement
  3. coolbreeze
    coolbreeze New Member
    10
    First I've heard of this, curious to know the outcome...
    Sent from my Pixel 3 using Tapatalk
  4. RS03_SEN
    RS03_SEN Well-Known Member
    526
    347
    Not what you want with a brand new car eh! Hope it gets sorted mate.
    Sent from my GM1913 using Tapatalk
  5. deepy
    deepy Active Member
    110
    81
    Yes it is common with these pan roofs although some don't have this issue. After purchase, mine developed a squeak when driving on /off the drive, the dealer lubricated the necessary parts but that didn't help at all. I decided to put up with it, but then a knock developed when going over uneven roads, so took the car in again and the dealer said the next step was to replace the pan roof which I agreed to. Got the car back and the roof didn't make a noise, great I thought, but after 3 days the squeak was back but the knocking had gone. The only consolation was that they made a good job of removing and reinstalling as there was very little sign of the work being done. Have decided to leave as is.
  6. Spinstorm
    Spinstorm Well-Known Member
    1,359
    600
    Same as above. Search the forum for roof issues.
    But my new S3 and RS3 both had their sunroofs replaced because of knocking/squeaking.
    The S3 issue was fixed by replacing the roof which I then traded in for the RS3 and that roof replacement has not solved the problem. It’s less bad. That’s all. I try to ignore it.
    I was without the S3 for 3 weeks for that work and the RS3 was 11 weeks (yes that dealer was far less competent).
    It appears the replacing it won’t make it worse but may not make it better so it’s your call.
  7. RS3 S.
    RS3 S. Well-Known Member
    992
    496
    My last 3 Audi's have had the Pano roof & all have been perfect,not one noise from any of them. I always look for a car with one,for me a must have option.
    Riko0073 likes this.
  8. Scottkcollins
    Scottkcollins Member
    95
    60
    Where as I will always look for one without as I hate the squeaking (had it on my merc really bad)
    pan roofs and sporty set up cars tend to have these issues I have found
    RS03_SEN likes this.
  9. RS03_SEN
    526
    347
    Same. Sunroof is the last thing I look for in a car.
  10. Riko0073
    Riko0073 Well-Known Member
    1,131
    1,004
    Yep, love a sunroof, just adds that extra something.
    Great today with the sun out but still a bit chilly and can really hear that exhaust without the intrusion of windows open and getting blasted.
    RS3 S. likes this.
  11. RS3 S.
    992
    496
    ......exactly & when the summer is over open the blind & let more light in. My favourite time is the Autumn as the leaves are changing with a bright sunny day shining in.
  12. Avatar
    snack-media
    Advertisement
  13. L1ARR
    L1ARR Active Member
    519
    72
    My car is a 2017 with 7k on the clock. The sunroof creaks when driving and moving on and off the drive. Dropped into my local Audi dealer who asked if it had been serviced. My immediate response was there is a well known problem with these pana roofs and greasing the rails will not solve this long term. Equally I am not going to pay for a service if the creaking will persist? The car is booked in on the 1st for a look.
  14. Riko0073
    1,131
    1,004
    I’ve never been asked to pay for simply applying some grease to the rails/seals.
  15. L1ARR
    L1ARR Active Member
    519
    72
    This was my response, hense pushing back heavily.
  16. simonali
    simonali Guest
    That's very helpful. Thanks for your input.
  17. Slowracer
    Slowracer Active Member
    316
    213
    43
    Mine is just about to get it's second sun roof replaced.
    The first one was quiet for a few months and then got progressively noisy. Dealer said that greasing will do little to help, so new one being fitted next week.
  18. L1ARR
    L1ARR Active Member
    519
    72
    Kee to see how you get on
  19. Sequence
    Sequence Member
    65
    37
    Thanks for all the input guys! I think i will let them have it and sort the issue after all its a hell of a lot of money to have issues like this.
    Shall see how it goes though not sure how well all things currently considered
  20. DannyRS3
    DannyRS3 Active Member
    200
    158
    43
    Have a look at this video if you are having creaking issues:
    I had a slight creak right off the dealer forecourt and found the drivers side screw was not tight at all, and came loose a few times in the last 1000 miles due to our terrible potholed roads. I've since lock-tite'd it and its perfect now.
  21. RS3 S.
    992
    496
    Drove home yesterday after work with the ''roof'' fully open,1st time this year. As in my last post even with air con it's still a must have for me. Gave the wind deflector & inside edges of the glass a good clean as well when i got back. Bit dusty & dirty after the winter, & my bad :redface new: as i haven't had it fully open this year only on tilt until yesterday.
    L1ARR and Riko0073 like this.
  22. Slowracer
    316
    213
    43
    Mine is open about 90% of the time, the other 10% it's raining. :)
  23. RS03_SEN
    526
    347
    Makes a weird noise my car with window open if I drive a bit fast. Actually hurts my ears.
  24. Paulbean
    Paulbean Member
    92
    64
    Phantom helicopter, or other half :friendly wink:? If it's the first, go faster, otherwise slow down.
    Riko0073 and RS03_SEN like this.
  25. RS03_SEN
    526
    347
    It does actually sound like a helicopter!
  26. HOGG
    HOGG Well-Known Member
    839
    279
    Open up another window a crack and it goes away
    Sent from my SM-G930F using Tapatalk
  27. Riko0073
    1,131
    1,004
    It’s good just to open the rear windows an inch or two, you get a nice draft in the cabin and no ‘helicopter’ noise when having the fronts open at certain speeds.
    But for me it’s sunroof open whenever I can.
    RS3 S. likes this.
  28. RS03_SEN
    526
    347
    I don't have one
    Turns out my cars original buyer wasn't into optional extras. Surprised the tyres came inflated.
    RS3 S. likes this.
  29. Spinstorm
    1,359
    600
    I love my sunroof for the reasons above...
    It is open 99% of the time. Heating on when it’s cold or raining lightly. And you can hear the exhaust.
    It also brings extra light into the cabin and makes it feel more spacious.
    I’d always spec a sunroof from now on.
    But doesn’t change the fact it squeaks. It rattled and I had a whole new sunroof and it still does that.
  30. RS3 S.
    992
    496
    ...........thing with Audi is they make a good car & then it's ''sorry'' but if you want a great car you need to spend a few more thousand pounds on out options.
  31. RS3 S.
    992
    496
    ..........shame your pano roof is playing up. As in my earlier post this is the 3rd pano roof from Audi i've had & not a squeak or rattle, but they still are a must have option. Really does make the cabin lighter.
  32. RS03_SEN
    526
    347
    You're right.
    You'd think the RS model would have everything. Here's our top car but it's not quite our top car, it's £8000 off our top car but still has the same badge as our top car.
    Fair enough do it with the basic models but I think the top model should have all the bits thrown in.
    Then again, mine doesn't have keyless start and I prefer that. Bit safer imo. Winding seats though on an RS is a bit of a **** take though. I had full electric seats on my 2011 Mégane RS.
  33. Avatar
    snack-media
    Advertisement
  34. RS3 S.
    992
    496
    Even on my 2016 RS6 there is no head up display or heated rear seats,couple of things that would have been nice on what must have cost the original owner close to £80,000 !!!!!!!!. Good thing i suppose about being the second owner it was a lot less than that.
  35. Russrs3
    Russrs3 Member
    61
    42
    The lack of electric seats is ridiculous isn’t it!? It’s the one thing that does my head in about my car, it’s so annoying when my wife drives it and adjusts the seat!
    Agree about the keyless as well, I purposely looked for a Sport Edition without the comfort pack as I didn’t want the keyless. I do miss the B&O speakers though... had them in my PFL RS3 and loved them!
  36. RS03_SEN
    526
    347
    Mine is PFL 2015. I have the B&O speakers and sub in the boot. They do sound ace.
    Once you've moved that seat it never feels right! The leather is knackered on my driver's seat too. Looks like something from car sos
    Russrs3 likes this.
