- Joined
- Oct 2, 2015
- Messages
- 3,565
- Reaction score
- 770
- Points
- 113
Hi I bought a replacement toy (project I expect) for my old v6 s-type jag MOT failure. And thought I would introduce myself with clearly a list of issues encountered so far.
I know it's not organised but and all future items will. Simple might just know an answer straight away. I have looked through some of the forum already.
What I have is 2001 S3 amk.
Stage1 remap
Variable booster tap in engine
Aftermarket air filter
I think it has a forge dump valve too
I changed plugs and a coil since misfire after 2 days of ownership.
Also ensured only put in super unleaded, and a petrol treatment.
It is running well, although untidy between gear changes and the release between gears sounds scrapey?
I have some cosmetics to do
Door blade - needs drilling off I expect and the runners repaired.
Trim in boot
Air con regas
Faults to fix
Occasional abs/esp lights appear, usually if I floor it. Might be the abs module dry solder joint? Although if possibly wheel sensor I can replace those.
Smells of oil in the cabin if stationary.
There was a damaged pipe between oil filter and hockey puck, just taped up. But am considering the pvs catch can to atmos solution. Does this get rid of all the little pipes above cylinder 3 and 4 or is that a different mod?
Car feels weird at speed.
I will check the rears for bearings and brake binding tomorrow.
Brakes seem a little soft to me and the handbrake is poor.
Well anyway it certainly seems like it will be a project, but something to hold its value if looked after.
Stage1 remap
Trim in boot
Air con regas
Faults to fix
