  2. Dismiss Notice
  3. Maintenance work on Tuesday 7th April
    Due to some much needed work to the servers we will be going off line for a couple of hours on Tuesday.
    Sorry for the inconvenience
    Dismiss Notice
  1. The Jargen
    The Jargen Member
    109
    22
    Hi all, regarding the new MOT are testers now physically checking to see if the dpf has been tampered with even though you may have engine covers and under trays fitted?
    Another question if you have had you dpf gutted (leaving the cat in place) what are the some of the smoke opacity readings you're getting?
    Thanks.
  2. Avatar
    snack-media
    Advertisement
  3. The Jargen
    The Jargen Member
    109
    22
    Hi Tosh26, thanks for getting back to me. Why was your car not tested to the plate value? I mean it would have passed anyway since its 0.5.
  4. Marky007
    Marky007 A4 Sline S-line owners group Team Silver saloon Audi A4 TDi Manual
    552
    164
    43
    Probably not a good idea to post your mot tester online :blink:
    Be last time you get an mot there with no dpf
  5. PenttisHSR
    PenttisHSR Active Member Audi S4 Audi Avant Owner Group Manual
    145
    As the DPF gets hot it is not normally covered or obscured by a plastic undertray, in fact the metal heat shield can be a fail now if missing near to the fuel tank. These often fall off . Yes the dpf is physically checked (visually) for signs of tampering. The tester is not allowed to remove any plastic shields or undertrays.
    Depending upon the year of your car, there are new limits now. The limit for each individual car is displayed on a sticker on your vehicle. This sticker is usually found in the door jamb but can be under the bonnet. The figure is in a square box on the sticker.
    The default limit for the newest cars is 0.70 m-1, so the car above would have passed that OK. The limit on the sticker is typically much lower than 0.70m-1. [The default limit is used if the sticker value is illegible].
  6. ktmpedro220
    ktmpedro220 New Member
    25
    Sent from my CLT-L09 using Tapatalk
