  2. Dismiss Notice
New MAF but g/s still low
Jade S3 Dec 16, 2010
  1. Jade S3
    Jade S3 270bhp 13.6 1/4 mile
    24
    Hello guys, im new here, been browsing over 2 and a half years ago though, alot of great cars and people here. My MAF used to flow between 183-189g/s before, then i fitted a new bosch maf and its still the same, what could be wrong? .
    Its clamped tight, screws are tight, airbox is clipped in properly. No boost leaks, tests were done to redline in 3rd gear, oem maf housing, standard fpr. Thanks
  2. Avatar
    snack-media
    Advertisement
  3. Jade S3
    24
    Boost is at 1.5 Bar/22 psi, very little timing pull. Only fault code is a G235 EGT sensor implausible signal intermittent, engine temp gauge was at 90 deg. Had enough fuel, ESP was off. Air filter is a new oem unit
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,099
    738
    Sounds about right with the mods unmapped?
  5. Jade S3
    24
    Hi dave, its mapped. Thanks
  6. s3dave
    10,099
    738
    Have you done any logs? is the splitr dumping to atmosphere?
  7. Jade S3
    24
    I've done logs, wont be able to post it now. No the dv is in full recirc. , aquamist is setup perfect.
  8. s3dave
    10,099
    738
    what injector size for your aquamist? are you running a mix or water? Have you tried it with the wmi off?
  9. Jade S3
    24
    Injector size is on the pump and thats behind the bumper lol, i run a 70% methanol mix with 30% water, cant switch it off because the map is aggressive and it will pull alot of timing. Btw the dv is set at 28 clicks and thats perfect on my car
  10. s3dave
    10,099
    738
    Do you think the ecu could be holding back because of the EGT fault?
  11. Jade S3
    24
    The unitronic dealer here says it wont, why would it hold back airflow yet give full boost/timing, its strange. The car supposed to be flowing 200+ g/s, sorting out the EGT next week
  12. Avatar
    snack-media
    Advertisement
  13. s3dave
    10,099
    738
    VCDS.... display groups 034, 043 and /or 046, channel 2 will give you sensor output... depending on revs can read from 350degC to 700degC
    apparantly If a sender fails, the charge pressure is reduced to a safe level and an emergency enrichment characteristic (engine speed-dependent) is used.
  14. sportstractor
    sportstractor Chugger
    2,698
    does it drive ok? not hesitant at all?
  15. Jade S3
    24
    Drives lovely, killed some pretty impressive cars with it. Launches great and still pulls strong in 6th, revs up quick and covers ground fast
  16. s3dave
    10,099
    738
    Is you fuel consumption low?, i think it is throwing fuel in....imo
  17. Jade S3
    24
    Its nasty on fuel, before i would get 1100km on a tank, now i dont even see half of that
  18. Welly
    Welly 335D Driver :-)
    10,698
    139
    Hmmmm. EGT is a very important piece of kit on the wideband cars. It not working properly may well have this effect.
    I'd deffo start with fixing the known faults.
