New injectors and MPG got worse?!?
Mollygoogle Nov 24, 2016
  1. Mollygoogle
    Mollygoogle Member
    290
    15
    2006 3.0 TDi
    Had the dreaded injector issue for a while. Sourced a full set with an "AG" suffix. Professionally installed and coded at the same time as a full service.
    The car drives like a dream. So smooth, a massive improvement over before. The smoke is gone. It no longer spews out on start up or acceleration and I dont have a James Bond style smokescreen when idling in traffic anymore.
    The big but though is that economy has dropped from 30 to 28 whilst maintaining driving style and journey type.
    The only other change is that since the injector change it has been ran on Shell super duper diesel rather than its usual diet of supermarket fuel.
    Any ideas?
    N.B. All figures are manually calculated and are backed up by a drop in miles covered
  2. Avatar
    Google AdSense Advertisement
  3. Simon968
    Simon968 Active Member Team V6 TDi Audi A6 Audi Avant Owner Group S-line owners group
    380
    52
    Could be down to the cold weather making the car take longer to warm up?
  4. Mollygoogle
    Mollygoogle Member
    290
    15
    Thanks for the suggestion. However, I do 500 miles a week and I've dropped 2mpg straightaway after the car being in the garage for less than a day
  5. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User TDi Audi A4 Audi Avant Owner Group quattro
    6,901
    3,323
    Are you taking the mpg figures off the trip meter or are you calculating mpg from fuel added? . The reason why you were getting all those plumes of white smoke is because of the diesel that was weeping out of the injectors. This diesel quantity was not measured by the ECU so it's calculation's would be incorrect.
    Now you have put in injectors that don't leak, the mpg measured by the ECU will be more accurate. I suspect that you may actually be getting better mpg than before.
  6. Mollygoogle
    Mollygoogle Member
    290
    15
    As per the first post, all figures are manually calculated and there has been a clear drop in mileage covered. I never use the duff information on the screen
  7. B5NUT
    B5NUT Well-Known Member TFSI Owners Group VCDS Map User Audi A6 Audi A3 Audi Avant Owner Group quattro S-line owners group S tronic
    4,626
    1,036
    How long have you had the injectors fitted?
  8. Mollygoogle
    Mollygoogle Member
    290
    15
    Last monday
  9. desertstorm
    6,901
    3,323
  10. Mollygoogle
    Mollygoogle Member
    290
    15
    No, "certified" as 45k on them. As said, car drives like a dream with them in, much smoother and the smoke is gone. Just the poor economy.
    The only other thing I can bring in is that the car was mapped by the previous owner and I havr no providence for the quality of the map
  11. B5NUT
    4,626
    1,036
    I would be looking to see if you can get the remap removed, I get around 35-36 MPG and I also fitted a used set of injectors almost 2 years ago. Before the injectors were changed I was only getting around 30mpg
  12. Avatar
  13. Mollygoogle
    Mollygoogle Member
    290
    15
    Would you recommend anyone locally?
  14. Simon968
    380
    52
  15. B5NUT
    4,626
    1,036
    Unfortunately I don't know any tuners in the local area. Bit of a long shot but you could ask Teesside Audi how much to re-flash the ECU with the standard map.
  16. Mollygoogle
    Mollygoogle Member
    290
    15
    Good suggestions, thanks guys
  17. desertstorm
    6,901
    3,323
  18. Mollygoogle
    Mollygoogle Member
    290
    15
    Darlington, local to B5NUT
  19. Mr DJ MOORE
    Mr DJ MOORE Member
    65
    17
    B5, I think you put a link in somewhere listing the injectors released for the 3.0 engines. I wanted to try and find a set of the latest released injectors over the next few months to make that another job ticked off my list. Was the list done by yourself?
