new headlight group buy
hydro s3 Dec 17, 2017
  1. Tj 0785
    Tj 0785 Well-Known Member VCDS Map User Bronze Supporter Audi S3
    1,952
    449
    You did reattach the little arms for the level sensor on the passenger side front and back
    hydro s3 likes this.
  2. Avatar
    Google AdSense Advertisement
  3. GeorgieS3
    GeorgieS3 Active Member It's my birthday
    304
    64
    Yeah that’s what I thought, but they are both in tact and back together as they should be after fitting lowering springs and dampers. Unsure if the lowering could affect it?
  4. GeorgieS3
    304
    64
    Yeah I’m pretty certain they are, but will double check tomorrow.
  5. Tj 0785
    1,952
    449
    Lowering shouldn’t effect it mines lowered 25mm and still does it on start up
  6. GeorgieS3
    304
    64
    ok pal thanks
  7. Tj 0785
    1,952
    449
    Without sounding like I’m taking the **** you did plug them in
    GeorgieS3 likes this.
  8. GeorgieS3
    304
    64
    Haha yeah plugged them in mate 100%
  9. Chromag
    Chromag Member
    70
    10
    This is good, when I get home in 10days you lot will have hopefully sorted all the teething issues and I'll be well versed in how to set these things up
    Sent from my E5823 using Tapatalk
    hydro s3, Langsam and GeorgieS3 like this.
  10. Stuart B
    Stuart B Well-Known Member
    2,610
    528
    your missus is going to tease you sending you pictures of headlights?
    Sandra and GeorgieS3 like this.
  11. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,174
    906
    @Alex C, I'm happy to have it back and sort, so its the Indicator reflector that is causing the problem?
    Send me a PM but all I will need back is the light, indicator bulb, and holder, wont need nothing else back.
    have you still got the cable tie and ball joint?
    @Gonzokew, if you struggle I will have that one back also to sort.
    Trups
    Alex C likes this.
  12. Avatar
  13. Midgley
    Midgley New Member
    19
    Any news on the last 4 to be sent out ?
  14. Gonzokew
    Gonzokew Active Member
    201
    66
    Update on my headlights and fitting experience:
    I had to take apart the adjuster motors and move the encoder (its on a slider) whilst plugged in to get the motor shaft to extend to its max position. Once this is done you can hook the ball end onto the socket.
    I managed to get the manual adjuster connected into the socket with some long nose pliers and a bit of patience. Got them adjusted at the garage and it's now passed the mot.
    Drove home in the dark last night and have to say... These lights are amazing :)
    Such a great upgrade. I've bought 2 sets of second hand headlights over the years only for the adjusters to break or they fade etc. I know now I don't have to spend any money on them again and they're 10 times better than the factory ones.
    Great job trups
    t8ups and Alex C like this.
  15. warren9022
    warren9022 Active Member
    134
    45
    Glad you got them sorted :footy:
    Is there anything I should look out for before I fit my set to the car to make sure they're operating as they should? Don't particularly want to have to take them off and re-fit them if I can help it!!
  16. GeorgieS3
    304
    64
    “Send me a PM but all I will need back is the light, indicator bulb, and holder, wont need nothing else back.
    have you still got the cable tie and ball joint?”
    @t8ups what do you mean cable tie a ball joint? Don’t remember seeing those when I got my set.
  17. warren9022
    134
    45
    I've been thinking the same thing wondering if I threw something away that I shouldn't have :tearsofjoy:
  18. GeorgieS3
    304
    64
    Exactly my thoughts haha
  19. t8ups
    2,174
    906
    was there a cable tie holding it the reflector back? this is the reason the rear cover was not installed.
  20. warren9022
    134
    45
    @t8ups Yeah I had a cable tie attached to the reflector and then to a piece of plastic the other end. I thought it was just packaging, what does it do?
  21. t8ups
    2,174
    906
    just packaging, holds the reflector tight for transit, that should be removed once your ready to fit and is not needed while the lights are in the car.
    warren9022 likes this.
  22. GeorgieS3
    304
    64
    Ok cool, thanks mate that clears that up, mine are now working spot on - required a new rear headlight level sensor due to a bodge done by a garage.
  23. drive2arrive
    drive2arrive New Member
    Any updates on the remaining units please T8ups?
  24. Langsam
    Langsam New Member
    21
    17
  25. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    632
    153
    43
    I emailed @t8ups this morning to find out bout the last paint ones. As I don't think he really follows the thread but no reply yet. If I get one and he hasn't answered on here I'll let you know what I find out.
  26. stevie e
    stevie e Member VCDS Map User
    47
    He's probably waiting for these to come back from the paint shop. Then he's got to put them back together. Well worth the wait . I was in the first group buy, these headlights are brilliant patience
    Stuart B likes this.
  27. Stuart B
    2,610
    528
    it's Saturday evening . but hey every day and night is a work day.
    superkarl and Tj 0785 like this.
  28. stevie e
    47
    Well worth the wait , these are like night and day , you won't be disappointed
  29. hydro s3
    632
    153
    43
    We have been try to get answers during the week aswell but have had no joy. We just want to know what's happening.
    On the 27th Feb we where told they would be ready by the end of that week but nothing and that's the last communication we have had.
    drive2arrive likes this.
  30. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,364
    390
  31. t8ups
    2,174
    906
    Hydro, I have not had an email? where did you send it to.
    Trims I got back from the body shop but I was not impressed as there where a flaws in Trim 1's, its like the clear coat reacted to something and bubbled up, trim 2 are perfect so brang them back.
    I went in last week and got told Friday they would be done but he was running behind and only managed to fully sand back the 1st coat that reacted, I am told this morning they are been painted tonight so I can collect Tuesday.
    Now, I cant rush him and push him as the price that he does me on paint work is too good, if I say push it through before other jobs then I would end up paying him more than its worth doing this stuff, I know that's not your fault but I'm trying to be as quick as I can but been fair. I need the last 4 sets gone, believe me, I'm not holding onto them, I would rather the 7 shelfs that these lamps are taking up to be freed up from these lights split.
    Will update tomo night.
    Ta.
    warren9022, Sandra and hydro s3 like this.
  32. hydro s3
    632
    153
    43
    I sent it to sales@emtuning.co.uk
    Thanks for the update and I don't want them rushed either just wanted to know what was happening.
    Sandra likes this.
  33. Avatar
  34. t8ups
    2,174
    906
    These 4 sets are the top of the list waiting to be marked off :)
  35. t8ups
    2,174
    906
    Just got back with the black trims, will be starting to build up in the next few hours and I'm going to try get in over the weekend if I can so I can have these last couple out my door asap.
    Thanks to all for waiting.
    Trups
  36. hydro s3
    632
    153
    43
    Sounds good. I'm looking forward to getting these on.
    Sandra likes this.
  37. hydro s3
    632
    153
    43
    Got home from work and had a nice surprise waiting. They look fantastic and will really look good when I get them fitted. Hopefully get them fitted over the weekend weather permitting.
    Big thanks to t8ups for putting the time in and doing this gb. 20180323_143809.jpg
    Langsam, Sandra, GeorgieS3 and 2 others like this.
  38. Gonzokew
    201
    66
    You won't be disappointed :)
  39. Langsam
    Langsam New Member
    21
    17
    Hopefully mine arent far behind yours @hydro s3
  40. hydro s3
    632
    153
    43
    Fitted them today well pleased with them. They make the car look a better and there nice and bright. The light faded to much for me to get a good picture so I'll get one in the morning and stick it up. Just one question I had a lead that doesn't seem to connect to anything what did people do with this when they fitted them?
  41. hydro s3
    632
    153
    43
    U will be happy with them. They will be worth the wait.
  42. hydro s3
    632
    153
    43
    These are the only pictures it will let me upload. Very happy with them. 20180325_144219.jpg 20180325_144208.jpg
    GeorgieS3 and ToughlilT like this.
  43. Chromag
    Chromag Member
    70
    10
    Can someone please tell me if I'm doing this wrong? Am trying to adjust these headlights and need to know they're not too high as people keep flashing me for blinding them.
    Parked 7.6m from a dark wall. Dipped headlights set at 1m in height and 1m apart. That sound right to everyone else?
