Hi guys can anyone recommend a good brand to go with. Got quite a lip on the front and back now and when I recently had the car serviced at Audi they recommended I get new disks and pads.
I went for pagid pads and rotors 2 months ago from eurocarparts . Happy with them so far If you change disks i would recommend getting new pads as well 2006 Audi A6 3.0TDI quattro sline le mans | Daytona Grey Pearl
Again, for normal road use I use Pagid and have done on several cars. Good, premium quality, aftermarket brand via Euro Car Parts. Replaced front and back on my A3 back in August, vented 312mm front discs and solid 255mm rear discs (plus all pads) and the total (DIY) was around £160.
Stock disc's with EBC yellow at the moment. I have 6 pot Brembo's ( Audi A8 setup) waiting to go on. I will do the same, stock disc's with EBC yellow.
That's good to hear, looking at fitting S6 set up but the A8 sounds better. Is there anything else needed to do this?
Not even different carriers, bonus. Will they fit under 18" wheels? and what size discs you using? Sorry for all the questions. Have you got any photos showing this set up?
You should get the carriers with the calipers. If not then you may need carriers. You can go up to 385mm disc's. I have 19's and know it will be a tight fit, so don't think 18's will be big enough. I don't have any pic's as mine aren't fitted yet. Look here for more info.......................http://audi.7zap.com/en/rdw/
I already have 347x30mm fitted, so it's gonna be close to get 385 in there. Wonder if anyone has a spare caliper/ disc I could try first ???
Well that's confirmed. Unable to fit any larger brakes unless I get 19" wheels and considering I've just bought new tyres only 2 months ago that won't be happening. Thanks for the help Pyeman, you've saved me some money lol
No probs. Double check, I have a friend that is running TT RS 370mm disc's and calipers with 18's. It would just depend on the caliper size. 380mm is only 14.9 inches, you have another 3 inches to play with!!!
Whats the reason for upgrade ? Are you doing any track days etc ? 2006 Audi A6 3.0TDI quattro sline le mans | Daytona Grey Pearl
You may be able to physically fit the disc and put the wheel on, but the caliper is what fouls not the disc. You can put 365/370mm discs on an 18 inch wheel but it is close. Any bigger and the caliper will be hitting the rim.
I didn't know that. Thanks for teaching me how to suck eggs. As I stated, it would depend on caliper size!! Caliper choice is key. I've have friends and myself, built loads with fag paper caps with calipers and its all worked fine.
I got Delphi discs and pads fitted to all corners about 200miles ago and so far good. Been advised discs are better than Pagid or few others from ECP and might change another set of pads before they'll wear off. Been quoted over 1k from the stealership but after emission recall they offered me half the price. Been quoted exactly the same from a local garage for these Delphi as supposed to the standard OEMs. Might be wrong (me or the guy who said so) but hope not
Oh ohhhh! Someone made me look like a fool now. Lol Thank you Hazwould. Will keep it in mind. Who is that list made by, by the way?
Ok, got it. It is made by ECP according to their recommendations, expected life span by manufacturers or their sales. Wish it would be voted by real users.
Pagid are good, but I find they generate a lot of brake dust. Going to try these next year. http://www.ate-brakes.com/products/disc-brakes/ate-ceramic-brake-pads/
im not 100% sure but i believe that zimmermann did/do make the oe discs for the c6 s6 i went for the oe in the end but the car is used for general purposes not for hooning and so far they have been fine although the standard pad/disc combo i expect trades off performance vs longevity
I know this is an old thread, but regarding OE manufacturers etc. But considering the main 3 that I can think of I would think that these are the better quality. ATE. TRW and brembo, Delphi and Bosch do also manufacture brake systems but no as common as the previous 3. The list writes by ECP is biased especially as their Textar stuff is way more expensive than the rest of the stuff. In terms of quality I’ve fitted Mintex and Pagid in the past. I’d say these are probably the best compromise of cost and quality but it’s all personal preference at the end of the day. I’ve got mintext pads and discs on my Touareg conversion and so far I’ve done juat under 40k and the discs barely have a lip and the pads have around 60% wear. A lot of motorway miles when I first installed them but for the last year I’ve done a lot more local driving so they are good on the wear front Sent from my iPhone using Tapatalk
I’ve used textar once and wasn’t impressed. although I’m under the impression they are under a bigger company called TMD friction. quick google shows TMD friction own textar, pagid, Mintex, Don and Cobreq. brembo in my opinion are the best OEM brake manufacturer. I’ve used comline discs before, I used comline discs on my TT running V6 brakes, and they brake well with the yellowstuff pads and coped with a trackday no problems, I’ve got a 360mm set up to go on something and that’s got comline discs too.
