NEED HELP a4 b7 sline cabby se tfsi 2008 bumper replacement
If you have a 2008 cab with s-line option is very likely you have the newer front bumper.
Does it have removable front foglamp covers?
bit of a rubbish online pic but give the basic design .
removableable foglamp grills and deeper front grille with 3 slot vents below, also has the built in lip curve on outside bottom edge of bumper.
1636919787736
an earlier version which can also be on s-line cabs but it's not the s-line as found on other B7 variants as above.
1636919918337
Eitherway, if you have the first type , then yes, a front B7 s-line bumper from an avant or saloon will fit, just ensure you get the same spec, ie, headlamp wash if you have that and PDC if that is fitted.
You can use an s-line from a b7 avant or saloon then, just ensure it's the same spec for options.
The facelift s-line front bumper from a 2008 cab is the same unit as found on the other s-line A4 B7 and S4 B7 variants.
Only difference between them is if you have headlamp wash and/or PDC options fitted, that said just look out for one with the appropriate options ready bumper.
Just as an advisory, even if you had the non facelift type , the two are still interchangeable , you would just need to change more parts.
Retro Fitting an s-line facelift front bumper is a very popular mod for cabs as they do look much nicer .
If you need more specific info look here at one of my sticky threads.
more info than you can ever need.
Same item and will fit straight on ,but ,it won't be suitable as you have headlamp wash and the one you are looking at doesn't , but it has PDC.
you need the headlamp option in any replacement , a lot of bumpers had headlamp wash and pdc but you just need headlamp wash.
worse case you could blank the pdc but there are lots of B7 s-line bumpers out there with either or option.
And if you have headlamp wash then you'll have Xenons fitted so the two go together.
if you don't want to get into repainting a used bumper, use your paint code to narrow down web search for used items, it does help narrow down things.
Oh thanks for that I thought that was what the hole was for lol I just realised what it is . Thank u so much for your help
You may want to check the fitting behind that corner of the bumper for any damage.
Intercooler, foglamp assembly and bits and pieces.
