  2. Dismiss Notice
Near side and off-side engine mounts the same size/fit?
VAG-Slag Apr 23, 2019
  1. VAG-Slag
    VAG-Slag Registered User
    1,856
    443
    I have a 2.0 tdi (BLB) and the engine mount on the passenger side has failed... It's the one with the electrical connector/sensor of some sort in, and is an Audi only part.
    Apart from the connector/sensor does anyone know if the mount is the same size and fit as the drivers side? . .
    If so I'd be tempted to buy an aftermarket part and either leave the sensor unplugged or put in a resistor so it doesn't throw a fault...
  2. Avatar
    snack-media
    Advertisement
  3. Sibmets
    Sibmets Registered User
    85
    15
    On my brother's B6 1.9 TDi he had a failed engine mount with a plug, he fitted a regular one without plug in it's place as that one was way cheaper I guess. If I remember correctly he didn't fit resistor because the fault inly came up in VCDD scan, but not on DIS so he just left it so.
    Also for part availability - MALÒ also makes engine mounts for BLB - haven't heard about them though, don't know If they are any good.
    Sent from my Pixel 2 XL using Tapatalk
  4. VAG-Slag
    1,856
    443
    Thanks for sharing... I've a feeling most the mounts are a similar shape and size tbh, so just going to have a punt with a cheap aftermarket one.
    Will let you all know how I get on!
    Sibmets likes this.
