  2. Dismiss Notice
Nav question.
Rob Band Nov 11, 2014
  1. Rob Band
    Rob Band Registered User
    66
    bbpc3 i think mine was 21055 or 20155 but i believe each one has a unique code , not sure though.
    There is an option in VCP that will search for it , it takes a little time though.
  2. Avatar
    snack-media
    Advertisement
  3. bbpc3
    bbpc3 Registered User
    thanks, i tried the 21055 already; wasn't able to get access to the right parts of the EEPROM. the keyfinder function is nice, but range must be limited so it would be good to know where to look for....
    is there someone else who can give me a code or a hint?
  4. Rob Band
    66
    I used the VIM method from the serial number and searched with VCP from that starting point.
  5. Whisky
    Whisky Registered User
    Hello, my name is Daniel. Pls help me with an advice.
    I have an Audi A4 with mmi 3g high navigation. I buyed a mmi 3g plus navigation unit. Display, center console, mmi unit and radio.
    I need to remove component protection for mmi unit. I have genuine VCDS and genuine VCP.
    With VCP i've managed to read eeprom in standard diagnose (security login key ok - i've find it with mmi 3g vim calculator) from old unit. adress 4096 from 640 to 770 hex Now write it in new unit eeprom. Problem is i don't know how to do it. I don't know how to find the key to login to engineer mode to be able to write new eeprom.
    Pls escuse my english. It is very bad.
    If you have time and pleasure pls shoot me a mail or a reply at this message.
    Kind regards, Daniel.
    P.S: I've send 2-3 mail to VCP support team, but i din not recived any answer.
  6. B5NUT
    B5NUT Well-Known Member VCDS Map User
    5,212
    1,301
    Another problems is that the can-gateway stores information on the current 5F module (serial etc), and only one 5F module can be registered on the gateway at any one time, so even if you managed to hack the old CP information into the new 5F module the gateway will not accept this and put the module back into CP,as it will see a new 5F module.
  7. Whisky
    I am 100 % sure that it can it can be done with VCP. 100 %. I've seen this done.
  8. Rob Band
    66
    Hi Daniel,
    Sorry for the late reply , i went to the dealer to have the CP removed , it was not possible any other way because from all the research I have done online i came to the conclusion that the Audi server has to approve the components to match.
  9. Cosmefulanito
    Cosmefulanito Registered User
    Hi, I have the VCP and I need to read the MMI eeprom to make a language change.
    Somebody can help me with the procedure to do that. I have the secuity code of my MMI.
  10. Cosmefulanito
    Nobody can help??
  11. mbrini
    mbrini Registered User
    Which modules do you have to upgrade?
  12. Avatar
    snack-media
    Advertisement
  13. B5NUT
    5,212
    1,301
    As per my Pm, your A6 C7 5F unit will not work correctly in a Q7. The can-bus system is different in A6 C7.
  14. mbrini
    Thanks, bought a Q7 unit and it's working fine. Only bluetooth menu is greyed out. any coding with vcds or Green menu?
  15. Bierbrunnen
    Bierbrunnen Registered User
    when I remember right you have to activate it in the green menu, let me check later
  16. Bierbrunnen
    sorry for my late replay, you can/must try this:
    1: open your green menu
    2: go to diagnose -> settings
    3: under point “Tel settings misc” change / set “../../noBT/noHFP” to “../../BT/HFP”
    4: reboot! your MMI
    5: go to 5F (MMI 3G / infotaiment)
    6: adaption - 10
    7: choose channel 17 – Bluetooth (internal)
    8: default value is 0 - change it to new value 1
  17. mbrini
    this is for 3G MMI, i have the MMI 3G plus, not the same green menu : don't have Tel setting misc but Tel setting, i checked the bluetooth and i enabled the internal bluetooth with vcds.
    I also updated my MMi firmware but still have the same problem
  18. Bierbrunnen
    Hiddenmenu main Page you have the Point "Bluetooth"?
  19. Bierbrunnen
    check if you can change something in the point "Bluetooth" on main page in your hidden menu, then
    go to tel_settings and activate "BT activation (bluetooth)",then
    go to diagnose/settings and check the point ami_aux, enable the points "AMI" and "AMI BT (bluetooth)"
    that should be enough, in case the above points are all already done but still no BT just let me know
  20. Warnen
    Warnen Registered User
    Hi guys I've got issue with my navigation. I've got 2005 Audi A6 (4F) C6 3.0TDI Saloon. My navigation failed to work, as not connecting to satelites. However it seems to see the satelites, because in the hidden menu/navigation/sensor data it shows 0/x (x=0-12) satelites, most of the time 0/9 or 0/12, but does not connect. Im living in southwest England, and here is often raining. [​IMG]
    I've already changed the gps aerial (4F5.035.503.G), and bought aftermarket cable from e-bay ( http://www.ebay.co.uk/itm/CEN-Fakra-Z-A ... 1735378712 ).
    My navigation comes back to work when we got a couple of sunny/dry day, but after rain it's stop working again. I understand, this could be water damage, my queston is: if the antenna gets wet, has to be changed? This morning i've applied some silicon around the fin from outside (when i changed the antenna, applied some silicone inside, and around the cup) so it has to be now waterproof. VCDS scan done this morning, got the following log:
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Control Module Part Number: 4E0 910 888 P HW: 4E0 919 887 C
    Component and/or Version: MNS ECE H41 1060
    Software Coding:
    Work Shop Code: WSC 00441 210 97470
    VCID: 3B6CD70BE36555DA0A32591-806E
    2 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 161813 km
    Time Indication: 0
    Date: 2016.07.01
    Time: 06:47:32
    02927 - DVD Read Error
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 225
    Mileage: 161708 km
    Time Indication: 0
    Date: 2016.06.28
    Time: 17:01:09
    Freeze Frame:
    Hex Value: 0x5772
    Hex Value: 0xAD55
    Hex Value: 0x0401
    Hex Value: 0x0000
    Just ignore the dvd read error, caused by lense cleaner disc i guess. Did i missed something? Is the aftermarket cable can cause my problem? If the gps aerial see the satelites, why not connecting?
  21. B5NUT
    5,212
    1,301
    If you have tried 2 GPS antenna and both give the same results then the nav unit must be faulty. It's not uncommon for them to fail, and I've replaced a few over the years.
  22. Warnen
    Thanks for the answer! :) Well...i don't think that i'll buy a new nav unit, as it is far too expensive. Even the used ones on e-bay Ł300-400...
  23. B5NUT
    5,212
    1,301
  24. Warnen
    Yeah, i already bought one of those, but still didn't work... this happend before i've changed the aerial.
  25. mbrini
    did all that, nothing worked, i even installed the new north american firmware but nothing
    Was playing in 5F adaptation and i lost my navigation data. navigation menu: navigation data is invalid. went to dealer: 150$ to scan and identify problem and then if i need a map at least another 500$. so i gave up and ordered another unit from ebay
  26. Bierbrunnen
    but you still have Access to the unit? if yes please send me a pm
  27. mbrini
    Yes i do. PM sent
