N/S/F brake disc only using outer half
S4_dan Jul 31, 2018
  1. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,856
    188
    Just picked at 53 plate Cab, and on the front brake discs, the PO has fitted new pads but the not discs. So, on the nearside front disc, the outer half of the disc is clean and the inner half of the disc is rusty and not being touch by the pad. O/S/F is all clean. doesn't pull when braking harshly.
    The brakes work but they are not as effective as they should be.
    Whats the best course of action to remedy this? Strip and clean the caliper, slider and carrier? Replace the disc and pads with brand new?
    Any other pointers?
    Cheers,
    Dan
  2. Avatar
    Google AdSense Advertisement
  3. Leo Komninos
    Leo Komninos Member
    119
    24
    Had the same on my B6, think I cured it by regreasing sliders with red grease. Also flushed system with new fluid.
    Sent from my E6553 using Tapatalk
  4. S4_dan
    2,856
    188
    Ah, new brake fluid! Good call, will get a flush done asap after cleaning the sliders and carriers.
    Thanks.
    Roland Wong likes this.
  5. Leo Komninos
    Leo Komninos Member
    119
    24
    Also there was a spring clip that goes on caliper. That was installed wrong too.
  6. QuattroCalum
    QuattroCalum Well-Known Member saloon Audi A4 Black Edition Saloon Manual
    1,942
    701
    The spring clip has no effect on braking, it's purpose is to stop the brake pads/calipers rattling over uneven roads. How did they have it fitted, do you have a photo that you could post?
  7. Leo Komninos
    Leo Komninos Member
    119
    24
    Was barely holding on. Couldn't replicate if I tried.
  8. matt66604
    matt66604 Active Member VCDS Map User
    232
    29
    Check sliding pins aren’t binding. Failing that check they’re not bent. And the spring clip on the front face of the calliper does make a difference but not as drastic as only using one half of the disc
