Car is a 2.0 Tdi CAGA Engine code
SInce last weekend I have had a really bad oil leak, the oil seems coming from the bottom end of the engine, the top end is bone dry. There doesn't seem to be any leaking from the sump.
The issue occurs once the car is up to temperature and the oil pressure has built up. So far this is this the list of things tha have been done:
-Oil Pressure switch - Changed
-Oil Cooler - Changed
-Oil FIlter Housing Seal - Gasket checked and resealed.
There is not much left to change in that region, however i'm not aware if there are any other pipes that are present which are out of site, I am also toying with the idea of changing the Oil filter housing. Tomorrow I plan to put a camera in and around the problem area, to see if the souce of the leak can be identified.
Any suggestions/advice would be greatly appreciated.
