Delivery day today from rushworth performance shame it wasn’t here yesterday but there’s always next weekend
It’s a sxe300 of some kind ha ar.96 he asked me what size inducer/exducer I wanted I just told them I didn’t have a clue and what I was hoping to make and he says that one will do it it’s heavy thing
@<tuffty/> I’ve just been informed that the variable valve adjusters should be all the way to the left when doing the chains is this true? I hope not I don’t think it was in the workshop manual if it is
Yeah panic over ( I hope) haha I just can’t remember doing it but must of to get it timed up properly
Looks like it’ll perform well on your setup.... not a turbo I’m familiar with, does look meaty Sent from my iPhone using Tapatalk
Bigger than I thought it would be but will see how it performs if I don’t get my results I’m after I will change it next year to a precision or g30 and maybe get the gravituned tubular manifold but I’m told It will get me My numbers
Yeah sorry fpr, gauge and the Cts fuel rail needs hose tail adapters have all the fitting just don’t know what to use ptfe,liquid loctite?
All my fittings were o-ring type (on the IE fuel rail)... obvs you don't use anything when attaching hose fittings to the AN male fitting as they are friction seal... If they are straight fit like on fuel pumps etc then you would typically use copper sealing washers... if they are taper fit then oil/fuel resistant thread seal (rather than thread lock)... I have used whatever Bill had kicking about at the time... was an orange coloured thread/pipe sealant by Forch iirc... <tuffty/>
Yeah it’s just the threaded part I’m on about not sure if they are a taper fit will check and see If I can pick some washers or correct thread seal up locally Cheers
So when dressing the turbo I noticed the ports aren’t drilled through luckily I was paying attention, anyway I’m going to use the vacuum port but are there any benefits on using the speed sensor port ? Or is it not needed for my goals?
It’s in but as always one step forward 2 back it’s very tight fit and is touching the heat shield and also looks very tight where downpipe / wastegate will go but hopefully do able I will have to look al T some hard piping to replace the coolant feed pipe from the header tank as the oem pipe sits to close to the turbo for my liking and looks a mess tbh
Was hoping to get more done but got rained off, still at least that’s one job done just looking into what’s best pipe to use for custom coolant lines at least now I can look at getting the fmic pipe work ordered up and fmic fitted
The one Badger5 uses is MAC. That’ll be the one they’ll use on my car Sent from my iPhone using Tapatalk
il use that one I need to keep an eye out for the ignitron ecu back instock so I can get them hopefully it’s before Xmas
Where to get high temperature silicone hose fitting for connecting on to the turbo for fmic and tip don’t want no cheap eBay copies
Hope you got some sense of satisfaction when you sat back and took that photo of the engine in place.
Definitely did, You start to realise how close you are to finishing when times I’ve felt out of my depth, few bits of coolant pipe to change, bit of wiring, fmic pipe work, tip, fuel feed to sort and can get it fired up before it’s off for custom downpipe I’m hoping @badger5 has more Ecu’s in by soon aiming for start up for new year
well spotted! Yeah will be able to do that in place should of really done it before but the test fit was that tight didn’t want to take it out again
It’s amazing how much room it takes up, when I saw PT’s it looked like there was ample room. Getting there Sent from my iPhone using Tapatalk
Nice work though... I suspect I won't get around to starting mine now until the new year... especially now I have changed my plans a little <tuffty/>
Those that have done the carbon canister delete, do you have to put a resister in the electrical plug or can it just be tucked away
So finally got the 4motion TB fitted and finally have some clearance the csf rad definitely made things tighter, removed the carbon canister to de clutter the bay abit but might try and fit the fpr in there as it’s a ****** big thing Can a fpr be fitted on the side? And does the inlet have to be the bottom port so it’s pushing towards the fpr for a accurate reading or could I use the bottom port as a return?
I plan on venting of the rocker cover straight to the tip I have fitted a new rubber in the pvc valve but not sure weather to fit a catch can aswell, how much do they actually catch? Have ordered a boost solenoid from badger5 and went on a mini spree also have ordered Black fmic pipe work kit and also ordered some proper clips for the joints Silicone 90 from turbo Silicone coupler for turbo intake 8mm Ali pipe for coolant tank return 16mm Ali pipe for coolant tank feed More 6an fittings and fuel line 102mm id proram air filter (it’s huge) Silicone hose for vacuum And arranged getting the 8 pot calipers posted for painting all while telling the misses I don’t need more parts good job we don’t have a joint account
I was emptying my catch can every 1000 miles. There would be around 50-100ml of oily watery liquid in it. I don’t plan of plumbing mine into the TIP on this build. I had been advised by various people including those in the motorsport industry that plumbing it back into the TIP means your engine has to burn it off, oil fumes naturally reduces the octane...... how much of that is true I’m not 100% certain. But I wouldn’t want my engine burning off the **** I find in my catch can personally. I’ll be venting to atmosphere, many are concerned with the smell, I didn’t really notice it with mine. Sent from my iPhone using Tapatalk
I agree, mine collects quite abit and it seems thin I’m glad I done that little mod after seeing what clogs up in all the pipes Sent from my iPhone using Tapatalk
