  2. Dismiss Notice
my s3 project build
hydro s3 Sep 27, 2017
  1. Tj 0785
    Tj 0785 Registered User Bronze Supporter Silver Supporter VCDS Map User
    3,877
    1,185
    Think I seen this in Facebook was that you, I’ve just ordered these last night when ordering new fuel rail for housing as needed new hoses aswell although I do think the price is a bit steep for them 2B77206D-5D8C-45CE-A15C-378660B16BCF.jpeg
  2. Avatar
    snack-media
    Advertisement
  3. hydro s3
    hydro s3 S3 amk
    1,363
    410
    @Tj 0785 yes mate that was me aking it and got a comment with that picture you have posted there I think they where £70 for that
    . I was hoping to just get the standard fittings instead of upgraded ones.
    I'll have a look for someone breaking one and see if they even have the whole evap can and fittings.
  4. Tj 0785
    3,877
    1,185
    You can have mine fitting if you want them il take them off tomorrow and post them out to you pm me your address, yeah I seen that funny enough after I already ordered some
  5. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Cheers mate that would be great. I'll do it now.
  6. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Got my radio wired in today with the bluetooth module and gps antenna and microphone. Makes the interior a bit more modern looking 20200521_171100.jpg Also got my heaters sorted they are now working as they should. It was the lead going into the heater matrix one of the wires had a split in it. New wire on it and now cold air is working again. Only took 3 different garages to eventually find the problem.
    tcg, Dohcwp, S3AMJ and 2 others like this.
  7. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Looks good mate I wondered when you were gonna fit it. Glad to see it all works
    hydro s3 likes this.
  8. hydro s3
    hydro s3 S3 amk
    1,363
    410
    @S3AMJ I'm well happy with it it only took over a year and half to get it all fitted and working but im more happy I got the heaters fixed. It was really starting to do my head in that no garage could find the problem and always had to have the window down cause the car got to warm
    S3AMJ likes this.
  9. S3AMJ
    S3AMJ OEM+
    2,198
    786
    I feel your pain, my aircon pressure switch has gone so I don’t have any aircon at the moment.... need to order one up and for it.
  10. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Definitely need your aircon working with the weather we have been having lately
  11. tcg
    tcg Registered User
    939
    464
    Spot on mate :thumbs up:
  12. Avatar
    snack-media
    Advertisement
  13. hydro s3
    hydro s3 S3 amk
    1,363
    410
    My map cd for the nav unit is a 2015 version. Can I just order a genuine 2019 or a 2020 one and put it in without having any problems?
  14. hydro s3
    hydro s3 S3 amk
    1,363
    410
    received_2664436943805286.jpeg Would anyone know if these wheels fit straight on with out adapters and I also have spacers 10mm front 20mm back if that makes a difference
  15. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Should fit on mate, you got brembo’s ok the front? From memory I think you need to run 10mm spacers for clearance. Don’t quote me on that.
    When I had them on my car I had 10mm front and 20mm rear.
  16. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Yes I've the brembos on mine and 10mm spacers on the front.
  17. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Would anyone know the part number for the intake camshaft position sensor?
    I have had a look but can't seem to see it on the one on the car.
    TIA
  18. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Hey mate, I believe it’s - 058905161B
    Some companies call it a “hall sender”
  19. hydro s3
    hydro s3 S3 amk
    1,363
    410
    S3AMJ likes this.
  20. hydro s3
    hydro s3 S3 amk
    1,363
    410
    What is the website called to check if wheels will fit to the car?
  21. S3AMJ
    S3AMJ OEM+
    2,198
    786
  22. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Cheers @S3AMJ that helps mate
    S3AMJ likes this.
  23. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Would anyone know the part number for the coil pack harness?
    I asked for a replacement one on the parts request here but they said it cant be replaced the old one would just need repaired.
    I thought I'd read on here that someone else had replaced theres.
  24. hydro s3
    hydro s3 S3 amk
    1,363
    410
    See the people that are using the colour mfa. See when you do the acceleration on it is the max power from the engine or the wheels? Screenshot_20200919-231152_Gallery.jpg
  25. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Is the r32 front and rear arb a good upgrade to do or would putting in powerflex bushes into the standard arb do a good enough job?
  26. S3AMJ
    S3AMJ OEM+
    2,198
    786
    I swapped out my rear ARB for an R32 with black series powerflex bushes. Difference was day and night. I know a few run the front R32 ARB’s and have said it’s made a real difference too. Depends what your planning for the car mate..... the odd track day or just B road mania haha. I bought my ARB through parts request and it was about £120 delivered back then. Bushes were around £45.
  27. hydro s3
    hydro s3 S3 amk
    1,363
    410
    It wont see any track days just the odd spirited drive. My front one at the minute needs the bushes done so if there is a upgrade over standard ones with powerflex bushes I'll go with that.
    How do you find the black series bushes for driving normal roads @S3AMJ
    I'll put a request in and see what price they are now if not I'll keep an eye out on fb for a 2nd hand one and change the bushes in it.
  28. S3AMJ
    S3AMJ OEM+
    2,198
    786
    The only black series bushes I’ve got on the car at the moment are the rear ARB bushes to be fair, I will eventually do all the bushes, but I’ll do some research and find out which is best where
  29. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Anyone know how I would get the part numbers for the the r32 front and rear anti roll bars?
  30. S3AMJ
    S3AMJ OEM+
    2,198
    786
  31. Brad1011
    Brad1011 Registered User
    187
    57
    BIGGER REAR ANTI ROLL BAR IS A MUST!! you probably don’t get the full benefit of the upgrade using it on road but what a difference it makes it actually makes the car enjoyable to drive and more sportier and dangerous I’m so glad I did it, mine was a eibach kit off demon tweeks which was trumpy as I bought front and back but I didn’t fit the front as I like it how it is I’d like to drive someone’s car with the r32 rear to see the difference with mine... maybe big turbo boy (AMJ) might let me try his one day
    hydro s3 and S3AMJ like this.
  32. S3AMJ
    S3AMJ OEM+
    2,198
    786
    You might catch me on a generous day, who knows bud haha
  33. Avatar
    snack-media
    Advertisement
  34. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Cheers lads I will have a read of that link now
  35. hydro s3
    hydro s3 S3 amk
    1,363
    410
    So a wee update,I have booked my car in with Bill for the 14th December to get my 2 nozzle meth kit,na cams and ignitron ecu fitted. Was going to get 3 switchable maps but on thinking more on it I think I'll just get 2 maps.
    A full race map with everything the car can give and meth depending and a map for just normal day driving.
    Tj 0785, Asim1 and S3AMJ like this.
  36. S3AMJ
    S3AMJ OEM+
    2,198
    786
    That’s awesome news dude! Hopefully my car should be built by then.... I’ll need to get mine run in and mapped before it’s MOT is due around then. Might pop over and meet up if this lockdown doesn’t extend
  37. hydro s3
    hydro s3 S3 amk
    1,363
    410
    That would be good mate to finally meet you after years on here and see this motor you got built.
    Hopefully the lockdown over there doesn't get to many more restrictions so it doesn't affect me to much getting home again lol
    S3AMJ likes this.
  38. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Yeah fingers crossed, there are rumours of extending it... but I think they’ll just be more strict with opening/closing times of some businesses. Time will tell.
    Either way I’ll see where I am and will try and have a proper catch up with you.
  39. hydro s3
    hydro s3 S3 amk
    1,363
    410
    So a we bit of excitement today after travelling since 9:30 last night.Dropped my car of a Bill's and had a wee chat and a brew.
    1st time I've spoke to him other than emails and maybe once on the phone. Just wish mechanics near me at home where as nice to talk to and explained things like he did or even where to do this kind of work. Top bloke and what a set up he has for the dyno. 20201214_114850.jpg
  40. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Got a email from Bill this afternoon to say that its running 357.9hp at 1.4 bar without meth at the minute.
    He said that it's at 1.4 bar at the minute with more to come so was just wondering how much more can it be pushed up to bar wise. I have asked him this in a email back but I dont expect a reply until after xmas but my curiosity has got me thinking of how much more.
    Asim1 likes this.
  41. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Sounds very promising mate! He will potentially take it to 1.8 bar all being well, that’s about the safe limits of the turbo. Things start getting very hot around there. I’d put money on you getting between 370-378bhp Maybe more who knows with meth.
  42. Brad1011
    187
    57
    What turbo is it mate ? I’m also trialling a front tt roadster front anti roll bar 3mm thicker with black bushes haven’t driven it yet will update on my progress, I’ve got a 24mm eibach rear as I know you were asking about them
  43. hydro s3
    hydro s3 S3 amk
    1,363
    410
    @S3AMJ I got a reply (which I was expecting as it was xmas) and he said he will take it to 1.75 bar as long as the boost keeps rising aswell.
    The fuel lets it down a bit I think as we only get 97 ron here.
    @Brad1011 it is running the k04-380 hybrid turbo package from badger 5.
    I got myself a r32 rear anti roll bar to go on when I'm doing the suspension upgrades.
    This is how hot it gets in there FB_IMG_1608837491051.jpg FB_IMG_1608837496734.jpg
    Asim1, Tj 0785 and S3AMJ like this.
