My S3 Build Thread
mechanic69
Well-Known Member
cool, did you find the source of that knocking in the end?
No mate it’s annoying the heck out of me!
guile
I know the feeling, I have an occasional slow speed knock too. Fairly certain it will be down to the solid shock mounts but it wasn't that bad when they were installed...
I have read half a dozen threads with these symptoms and nobody ever appears to find the cause, good luck...
mechanic69
Well-Known Member
reckon this will sort it
TyrolSport DeadSet Rigid FRONT Subframe Collar Kit ALL MK5 6 GTi Golf R S3 Leon
Stop the dreaded Subframe Clunk/Squeek!!
+ new top mounts and bottom ball joints
mechanic69
Well-Known Member
Fitted, what a ****** trying to line it all up but done now!
Not sure if it has done the trick tho till I get the 034 upper mounts swapped out
mechanic69
Well-Known Member
Having run the 034 motorsports top mounts for a couple of months now, I’m going to swap them out for standard mounts, the noise of the suspension is doing my nut in. Fine for track use but to noisy for road use
Finally swapped these buggers out for stock mounts, oh my god so quite I love my car again, worst mod I've ever fitted. Best thing is the uprated engine mounts are unnoticeable.
Reactions: S.
mechanic69
Well-Known Member
mechanic69
Well-Known Member
Fitted Vagbremtechnic J-Hooks and DS2500 pads all round. great stopping power, nice bite. Then did the DSG oil change.
mechanic69
Well-Known Member
mechanic69
Well-Known Member
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
Nice, 6pots?
I say there ****** big Brakes , was on an S3 saloon which is in the process off getting tuned to over 640bhp but alas not mine
mechanic69
Well-Known Member
What’s the difference after fitting? Any noticeable improvement?
Not got round to fitting yet, there is quite a weight in the box and a lot of work to fit, still weighing it up!
mechanic69
Well-Known Member
paddy
I ordered some Vagbremtechnic J-Hooks like yours, where did you get your DS2500s pads ? seems they are more expensive than the discs !!
leshkin
Hold my beer...
This stuff is heavy, but if properly applied will improve speaker sound quality massively as well as reduce outside noise a little. I have some of this on door skin behind speakers as well as flat panel areas of the door skin. No benefit in covering every panel fully - 20% coverage will be plenty.
For noise proofing there is a foam material that is good too and that stuff needs to fill the spaces in the door cards.
mechanic69
Well-Known Member
I think it was awesome, and yes they are expensive but they are good, I was struggling to find rs3 pads anywhere else
mechanic69
Well-Known Member
LEYO unboxing
Lovely piece on work good job lads
No idea if it adds any benefit but who cares couldn’t resist
Reactions: S.
ch1z64
Silver Supporter
Liking the Sofa cause i don't know what the new shiney bit is for :welcoming::welcoming::welcoming:
mechanic69
Well-Known Member
It replaces the DSG plastic filter housing with a shiny metal one
tcardio
LEYO unboxing
so sad that some of the most beautiful pieces on our cars are hidden. I love that part
Reactions: S.
mechanic69
Well-Known Member
So true but you know it’s there
mechanic69
Well-Known Member
MWright
LEYO unboxing
That looks rather nice and shiny.
You planning on getting the metal oil filter housing to match.
mechanic69
Well-Known Member
Probably next oil change
mechanic69
Well-Known Member
mechanic69
Well-Known Member
finally thanks, replaced all bolts for front subframe, alks, arb and steering rack, then torqued properly with 90 deg on top.
a lovely quite front end sweet
mechanic69
Well-Known Member
mechanic69
Well-Known Member
front end is so much more responsive, not sloppy, point and squirt love it
mechanic69
Well-Known Member
Time to sort the rear subframe out
IMG 0110 1
mechanic69
Well-Known Member
the next best thing to spending my money is looking at this thread and seeing others spending theirs. I love build threads. Whip is spot on!
Cheers man
mechanic69
Well-Known Member
Box full of shiny things arrived today
Rob C
Audi Owner
How come you're moving away from the B8s?
And did you go for the B14 of B16s?
mechanic69
Well-Known Member
Overall I was really happy with kit but the front right shock is not feeling/sounding right, I also want to tweak the ride heights so I’ve got the b14 kit, awesome we’re running a discount
mechanic69
Well-Known Member
Rear subframe Tyrol bushes and 034 bush inserts fitted, well nearly couldn’t get two of the top bushes in as the subframe wouldn’t line up. 75% done tho
leshkin
Hold my beer...
Nice! Any pics? Would you say that this is a worthwhile mod on a road car?
mechanic69
Well-Known Member
No idea mate, all I know is the Tyrol bushes on the front sub really make the front end solid and steering is so much more sharper and more responsive. So I figured it would be a similar effect at the rear. Just removing any sloppy ness in the rear sub.
Probably OTT for the road but I can’t help buying new bits
