My next new project has begun...
WOMBLERULZ
Halfway through on my s4 seats and replacement carpet
I'm Just Rob.
Moderating or something,
Staff member
Moderator
Gold Supporter
Ok back to the project chaps.
Collected the Bumper part of the project from @GDCAUDIA4B7 and well chuffed with it so a big thumbs up there.:thumbs up:
It's almost too good to repaint black but needs must.
A few things too prior to repainting.
The RS4 grille covers are too big, I did suspect they might be but hoped there may be a chance to cut them down a bit, sadly it won't work so new DTM vent covers are needed but not the end of the world.
As the DTM doesn't have foglamps I'll delete mine, not a loss as i don't go out in fog much anyway..lol
It has Headlamp wash but only grille PDC mounts so I'll need to sort out fixing the two offside sensors.
I have a plan for that.:yes:
So very pleased so far.
rob
I'm Just Rob.
Staff member
Moderator
Gold Supporter
My plan for the missing PDC sensors is this.
As there is no mounting hole in the bumper at the moment and the sensor mounting point on the inside of the bumper is not there I'll need to fabricate something.
The sensor body is 22mm OD, I'll use a step drill to get a nice round 22mm hole in the bumper to start with.
The next part is to get a block of suitable material just big enough to hold the sensor securely and provide a secure pad on the bumper, use a 22mm holesaw to cut the retaining hole in the block.
Affix the block to the bumper with tiger seal, when all set, insert the sensor through the block and secure it in place, that way the sensor will be secure and I can adjust the position of the sensor until the face is flush with the surface of the bumper, it will look as OE as you'd get that way.
A pretty low-cost solution that should work fine.
Using something like this to fabricate small mounting block for the sensors.
lightweight , strong and easily worked , very bondable aswell.
Acetal block
Alex Holmes
As you've already said Rob the oem sensor mounts are upto the job. I used second hand ones and cleaned them up and re applied some bew adhesive and they've been spot on so far. Might be work getting hold of some adhesion promoter too before sticking them on:icon thumright:
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Cheers chaps for the feedback re the PDC, spot on as usual.:icon thumright:
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Going to have another think about chopping the rs4 fog covers around a bit to suit, i have a plan..:yes:
Pie-eyedpiper
part 1 is a set of these which i ordered on friday.
Getting back to a close match to the oe ronal's but a bit better.:icon thumright:
Lovely OZ Racing wheels Rob.
Reminiscent of the 1990s A4 BTCC.
And being a bus will bring back memories of the Volvo 850. Only much better.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
I'm thinking that maybe a case of picking up a set of used DTM covers cutting out the mesh so i just have the outerframe then cutting out the area i require inc the foglamp section from the rs4 covers.
Then a case of rebuilding the two parts, sounds doable , will need to find a set of used DTM vent covers first as I'm not spending £100 for a new pair just to cut them up...
I'm Just Rob.
Staff member
Moderator
Gold Supporter
For a short while today I thought I'd solved the grille cover problem as the Audi S4 B7 25 Quattro
also has the DTM bumper as OE fitting, I noticed a few with foglamp grill covers but as yet the source of the covers has illuded me.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Bumper off to the paint shop next week so I need to sort out what grille colour to use.
I love the current colour scheme it has but that just won't work on my black bus which is a real shame.
I think I will be getting the grille surround done in satin silver again to ad some contrast, too much black otherwise.
Next item, Rings or no Rings that is the question.
The current grille fitted to the DTM bumper has no rings and looks good, I like the looks of rings but maybe too much on this grille.
thoughts guys.
norad97
Grill looks fine as it is, if you fit chrome rings it would just break up the black.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
I think you're right Richard, nice to have another pair of eyes on it.:thumbs up:
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Thanks chaps.:yes:
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Black surround on black bumper?
I'm Just Rob.
Staff member
Moderator
Gold Supporter
I think it needs a satin silver surround if not using rings, its a tricky one.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
and now i'm even more confused...lol
I'm Just Rob.
Staff member
Moderator
Gold Supporter
has to be satin silver , this is an rs4 bumper but very similar style to dtm and black with satin silver looks nice , and leave the rings off.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Black cars are a pain sometimes..lol
I'm Just Rob.
Staff member
Moderator
Gold Supporter
but then again, gloss black did look nice aswell, with rings.
choices , choices....
Pie-eyedpiper
Can you just fit black rings Rob?
An Audi's gotta wear rings.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
my first OE rs4 grill with gloss black surround, I'm not sure still, different pics of the same grille on the same car that look very different.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
could be a "flipping a coin" situation..lol
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Or buy a 2nd grill with a silver surround with rings and see which looks best out of the two fitted.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Rings are a must without doubt. :yes:
that's one part solved...
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Maybe i should just change the colour of the car..lol
