Vex182
1x S3 and 3x Fiestas.
Sooooo I used to have a Silver S3 for nearly 6 years and sold it in October 2016 and brought 2x new Fiesta’s for me and the mrs to replace her aging Fiesta.
Fast forward to March this year and I had decided that as we still had the 15 year old Fiesta and the 2 new ones, it won't hurt to get a 4th car! To be fair, I had been using the old Fiesta for work meaning it was doing 500-600 miles a week. Started looking into S3s again and felt like maybe moving to a 8P shape as the budget I was looking at was around 10k. Then I decided that I preferred the 8L shape still more. After looking at 5/6 different ones, I found this one owner Ming blue S3, 75k, 1 owner from new and a great spec. (Sunroof, cruise control, double dim Symphony with Bose, heated seats, arm rest with 2x cup holders and parking sensors. Anyway, pictures!
This is just after it was dropped off from the garage and I gave it a good wash.
After driving it for course before purchase, I knew the car was good and completely standard. Just a few niggling normal 8L issues to sort.
Brief list of what I then did (Not all work was needed but made sense to while doing other bits):
After this I went off to my stag do in Ibiza for 5 days and told the lads what I had brought, when I got back, the car felt nicer to drive after the refresh and I guess very OEM from what it would have felt like when it was new back in December 2002.
Since then, I have also changed the coil packs and gone for OEM spark plugs. Did a dry compression test and all cylinders were coming out at 178-180 psi which I was pleased with. Car has done around 500 miles by now. I then dropped the sump and degreased it and changed the oil pick up pipe (which was clean) and replaced it anyway with a new rubber seal, OEM sealant and new bolts.
New oil and filter sorted of course again. I then changed the gear box and transfer box oil with OEM oil.
I then took 2 weeks out and went and got married
Anyway! I came back and changed the rocker gasket for OEM and used the gasket sealant in the required places. Good degrease of the rocker cover while I was at it. My new number plate arrived which I got round to assigning.
Then I took the car to work to make sure it was all good! 100 mile round trip.
Since then, I have added 10mm spacers front and 15mm rear to improve the stance a bit
Also fixed a niggling fault with a fixing under the bonnet
Also as I want to keep this pretty OEM feeling and just doing adjustments that aren't permanent or fit in with the age of the car:
I have just added mk4 flat wiper arms and blades which suit the car more. Also added the ambient lighting to the S3 at the front (will take a photo at some point) which adds a little more light to the gearstick area at night when the lights are on at night. Added new boot struts with helper springs so the boot pops open on the key button.
The rear anti roll bar has now been replaced with a R32 19mm and added super pro rear bushes.
I had a guy come round and make me two new keys that look a bit more modern, other two originals are kept in the safe just in case
- New OEM shocks/springs all round plus fixings
- Powerflex top mounts and bearings
- OEM Porsche oil cap
- OEM Diverter valve
- OEM inlet manifold trim
- OEM engine bay cover fixing bolts (x5)
- Meyle HD front drop link
- Meyle HD rear drop links
- Turbo intake pipe plus caliper bolts from Badger5
- Thermostat from Euro car parts
- Full coolant change from Euro car parts with coolant and distilled water
- Larger lower engine mount bush changed to red Powerflex
- Forge DV and N75 pipes plus fittings
- OEM N75 valve plus fittings
- Forge brake booster pipe plus fittings
- Powerflex black steering rack bush
- Set of front and rear discs from Pagid plus OEM carrier bolts
- Set of front and rear pads from Pagid plus OEM caliper bolts
- New window clips fitted on n/s door (O/S was already changed when I checked).
- Mann pollen filter
- Mann fuel filter
- Mann air filter
- OEM Quantum Platinum engine oil change
- OEM Haldex 4wd oil change
- Haldex earth strap replaced
- OEM Audi dipstick holder
- Alternator from Euro car parts
- Drivebelt from Euro car parts
- OEM headlight to slam panel rubbers both side (Full length)
- OEM VW rear brake helper springs
- OEM Audi S3 8p gear knob and gaiter
- Full set of premium car mats
