My First Vcds Scan
Tank.
So after finally purchasing VCDS and it arriving yesterday i got outside this morning to have a play around.
so heres the faults from the first scan
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394G0057568296
Coding: 0000001
Shop #: WSC 02331 785 00200
VCID: 234393C0E2D7FF06A65-8076
2 Faults Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 90179 km
Time Indication: 0
Date: 2014.08.08
Time: 10:12:23
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 90905 km
Time Indication: 0
Date: 2014.08.20
Time: 15:44:39
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 L HW: 4E0 919 887 C
Component: MNS ECE H45 0690
Revision: 00000000 Serial number: 305GK057613344
VCID: 36655A9441457AAE71B-8063
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 89884 km
Time Indication: 0
Date: 2014.08.04
Time: 22:04:28
Freeze Frame:
Bin. Bits: 0100
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 C HW: 4F0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 11820518300727
Coding: 0201116
VCID: 244190DCE7D9F83EDFF-8071
3 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 5
Reset counter: 192
Mileage: 90060 km
Time Indication: 0
Date: 2014.08.06
Time: 09:16:46
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 12
Reset counter: 175
Mileage: 89884 km
Time Indication: 0
Date: 2014.08.04
Time: 21:34:20
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 175
Mileage: 90559 km
Time Indication: 0
Date: 2014.08.13
Time: 16:40:40
Although the parking sensors show faults at 3 positions i did change the positions around, as i know two of them are definitely faulty
any tips/advice to remedy the other problems above?
Just go ahead and clear the faults bud, re scan in a few weeks to see if any of them come back.
They could be nothing to worry about if everything is working as it should.
What rewtor51 said re scan after a week. I don't have VCDS but the first scan I got had lots of faults, had them cleared and they have not returned :)
was scanned by a friend a couple weeks ago, nav fault was present then, the radio antenna is a new one although i have had the rear bumper off in the meantime, so possibly disturbed something in the process
