  2. Dismiss Notice
My Belated build thread
S3AMJ May 20, 2018
  1. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Thanks mate, to be honest I think it’ll be to big for my setup like PT mentioned. So I’ll go with a 1.5” from Bill. Good price though.....
    hydro s3 likes this.
  2. Avatar
    snack-media
    Advertisement
  3. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,362
    5,601
    I suspect it would need more boost than they suggest to reach those figures taking into account pumping losses through the charge system and engine itself...
    Interestingly they spec'd a 3576 so same turbine size but smaller comp wheel than my 3582 (same comp wheel size as a 3076 essentially)... not compared the compressor maps though..
    S3AMJ likes this.
  4. hydro s3
    hydro s3 S3 amk
    1,363
    410
    When ur breaking the s3 you have could you see if you can get the trim for the top of the windscreen out. I've tried to get a new one and audi said it was discontinued at the start of the year and the one in my car is perished and needs replacing.
  5. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Hi mate, I’m not breaking my S3, I’m breaking the A3. Which trim are you thinking of? If it’s the same on the A3 then your welcome to it. Dunno when Badger5 are starting work on the cars, they’ve been really hectic moment. Soon hopefully.
  6. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Not sure if there the same mate I just thought you where in the middle of the breaking at the minute for some reason.
    I've actually just started a new thread as there is 2 in 2 different TPS places in England but they wont sell to the public.
    Thanks anyway mate
  7. S3AMJ
    S3AMJ OEM+
    2,198
    786
    It’ll be getting broken soon hopefully mate, I’ll be listing all the parts on here once they are off. The A3 is at Badger5 place, soon as they can start my next build they’ll be on it. Already sold my engine that’s in my S3! Even though it’s still in the car and I’m still driving it.
    If they are the same part then like I said your welcome to it.
  8. hydro s3
    hydro s3 S3 amk
    1,363
    410
    It's a job I need to do as soon as. Mine is that bad when it's cold outside the inside of my window freezes lol.
  9. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Ah ****... yeah not ideal, guess that means you’ll need to get the windscreen out and put back in? Surely the windscreen being sealed would prevent that from happening though?
  10. hydro s3
    hydro s3 S3 amk
    1,363
    410
    It's not sealed correctly as the sides aren't in the runners properly either but the strip at the top will need replacing so need that part 1st. Hopefully get one sorted in a couple of days
  11. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Ahhh I see, well hope you have some luck with TPS ask TJ he orders quite a lot from there. Sorry I can’t help you out this time mate.
  12. Avatar
    snack-media
    Advertisement
  13. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Cheers mate I will ask him
  14. Tj 0785
    Tj 0785 Registered User Bronze Supporter Silver Supporter VCDS Map User
    3,877
    1,185
    since Covid started I’ve not had anything from them as they bring really strict because they were only doing deliveries, I got a local garage to order some bits for me and gave them
    A few quid extra for a drink
    For the sake of £12 I was going to register as a ltd mobile mechanic company just to u could open an account but they also Want letter head and business cards and will only deliver to that one address
  15. S3AMJ
    S3AMJ OEM+
    2,198
    786
    It's official the G30-770 Stroker build is about to commence lift off. All work will be carried out by none other than the legendary Badger5
    I will do my best to document as much as I can with the build, the spec of what's going into my S3 is below -
    Head
    AGN N/A Rocker Cover
    AGU Large Port Head
    BadgerSpec Cams
    Catcam Adjustable Vernier Pulley
    Supertech Inlet Valves
    Supertech Exhaust Valves
    Catcam Gold Springs and Retainers
    Inlet Manifold
    Phenolic Large Port Inlet Manifold Spacer
    Tuffty Special (one off) Inlet Manifold
    Direct Port Water Methanol Injection
    Audi S5 70mm Throttlebody
    Block
    83mm Bored AGU Block
    JE 83mm 9.25:1 Stroker Pistons
    Hurricane I Beam Rods
    TFSI Forged Crankshaft
    Billet Main Caps
    Fluidampr
    Turbo & Exhaust
    Garrett G30-770 0.61 (Ceramic Coated Hotside)
    44mm Turbosmart Wastegate
    Nortech 1.5" Manifold (Ceramic Coated)
    3' Downpipe
    3" Turbo back Zinram Exhaust (Already on the car)
    Intercooler
    Custom Toyosport Intercooler and pipework (Already on the car)
    Water Methanol Injector Post Intercooler
    Tuffty Special Charge pipe
    Tuffty Special Post Intercooler Pipe
    Custom 4" TIP
    Forge Motorsport Supersize DV
    ECUs
    Ignitron (Already on the car)
    AEM Water Methanol Controller (Already on the car)
    Gearbox
    Gas&Gears Built 02M 6 Speed Gearbox
    Steel Selecting Forks
    3-6 Monster Performance Gearset
    4th Gear Support
    Clutch
    4 Paddle Sachs Clutch
    LUK Dual Mass Flywheel
    Brakes - (Already on the car)
    Leon Cupra R Brembo Calipers
    MTECH Grooved Discs
    DS2500 Pads
    Standard S3 Rear Calipers
    Badger5 Braided Lines Front & Back
    Fuelling
    Bosch 1000cc Injectors
    DW65 4WD In-tank Fuel Pump (Already on the car)
    044 Bosch In-line Fuel Pump
    Crank & Head Breathing
    2x AN10 Rocker Cover Adaptor (welded to AGN rocker cover)
    Cloud Nine Billet Crank Breather Adaptor (with AN16 welded on)
    Custom One off 2 Litre Carbon Fibre Oil Catch Tank (AN16 inlet and 2 x 35mm air filter outlets)
    I think this covers everything, as you can imagine I'm very excited. I will put up pictures as the build goes. Very intrigued how the G30-770 performs.
    ADs3, Tj 0785, Asim1 and 2 others like this.
  16. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Brilliant news mate very excited for you.
    That's a impressive list of parts and it will certainly drain the bank account lol.
    Look forward to see any pictures. Any idea on how long its supposed to take or is just a case of when it's done it's done?
    S3AMJ likes this.
  17. <tuffty/>
    24,362
    5,601
    I'm Speschial :)
    S3AMJ likes this.
  18. S3AMJ
    S3AMJ OEM+
    2,198
    786
    It’s not as bad as you think, bare in mind I bought that A3 with the stroker engine in it, so with selling all my parts it works out quite well. Time wise I don’t know but roughly mid to late November.
  19. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Hahaha oh yes! Very mate
    <tuffty/> likes this.
  20. Bluepower
    Bluepower Registered User
    269
    79
    Oef, that will be a very nice build! and a weapon on the street and track!
    S3AMJ likes this.
  21. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Should be very tasty for sure! Be good to see what it’s torque onset will be like with that turbo especially for when I do the odd track day, pulling out of corners and so on.
  22. S3AMJ
    S3AMJ OEM+
    2,198
    786
    So here is a a couple pictures of my custom one off carbon fibre oil catch tank. This originally came off a drag Mitsubishi Evo car. Serious bit of kit, the only thing I’m struggling with is distinguishing the size of the big AN fitting, the original owner seemed to think it was AN16 however now I’m measuring everything up ready to buy parts...... this seems to be more like AN20!
    I’ve measured the internal size and it’s 26-27mm where as an AN16 is around 22mm.
    Can anyone confirm that I’m on the right tracks here?
    Asim1 likes this.
  23. Asim1
    Asim1 Registered User
    446
    149
    43
    Was going t
    Was going to ask for a picture of this. That's one good looking bit of kit
    S3AMJ likes this.
  24. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Thanks dude, yeah it’s real nice.... not baffled which is odd! That’s said I’ve figured out a good get around for that, I’ll post up pics showing that next week.
    I’ve ordered a AN16/AN20 double ended spanner for £5 this will confirm which it is, I’ll be needing the spanner anyway. Once that’s confirmed I’ll go about ordering the rest of the fittings
    Asim1 likes this.
  25. Asim1
    446
    149
    43
    Cant wait
    S3AMJ likes this.
  26. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Little update today, more to follow tomorrow. I collected my 02M 6 Speed gearbox I’m getting sent down to Gas&Gears to get built up.
    Gave it a bit of a clean before taking it over to Badger5, who are kindly getting it transported to Gas&Gears for me along with my other gearboxes in part ex.
    I’ve polished this up so you guys can see it more clearly, but as you can see.... this isn’t a gearbox that’s normally associated with the 1.8t 20v engines! A 02M 6 Speed Quattro (FEK Code) gearbox naturally resides in either an A3, Golf or Bora 1.9TDi.
    The reason why I’ve decided to go with this gearbox is because it has slightly taller final gear ratios. 3.1 and 3.9. This will mean I should be able to potter around in 6th gear doing 70mph on the motorway @ 2200rpm. Instead of 3000-3200rpm. Better fuel economy and not so noisy.....
    It also means I will achieve 65-68mph in second easily, with the help of a 8200-8400rpm redline. Then from 3rd gear onward I’ll be in dog box mode with the monster performance gears.
    danny_dj3 and Brad1011 like this.
  27. Brad1011
    Brad1011 Registered User
    187
    57
    Love it so jealous !
    S3AMJ likes this.
  28. S3AMJ
    S3AMJ OEM+
    2,198
    786
    I was jealous of the guys running big turbo builds a few years ago mate, you’ll have your turn soon enough don’t you worry
  29. Brad1011
    187
    57
    I’m happy for ya mate it will be a quality motor and most importantly you actually use the car
  30. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Yeah couldn’t imagine just putting it in a garage for years. It’s my weekend car, occasionally I’ll take it to work but that’s a 170 mile round trip each day. Don’t fancy clocking up the miles on it just for the sake of it.
  31. S3AMJ
    S3AMJ OEM+
    2,198
    786
    So today I dropped off my gearbox at Badger5 and had a good catch up with all the guys. Took a couple pics of the G30-770 which turned up a couple days ago.
    Size comparison to the tape gun, she is a beast! Amazing build quality, beautiful finish.
    This is a picture of my G30-770 next to a GTX3076r Gen II on the right.
    Very very similarly sized however the G30-770 should yield better spool, more bhp, etc. The G30-770 has a bigger compressor wheel, slightly bigger compressor housing and a compact but wider turbo housing.
    Looking forward to how this performs!
    Also further discussions with the guys, we’ve decided to go 3.5” downpipe instead of 3” which will then mate up to a 3.5” Zinram exhaust I’ve just ordered as such my 3” Zinram exhaust will go up for sale.
  32. craigt1985
    craigt1985 Registered User
    235
    50
    Turbo looks shiny! Be interesting to see how it performs compared to the older tech.
    I'd be keen to buy the Zinram exhaust, was looking to buy one direct anyways, give me a PM when you do decide to sell it :)
  33. Avatar
    snack-media
    Advertisement
  34. ADs3
    ADs3 Active Member Silver Supporter
    403
    129
    43
    Any progress on the wmi as to why you wasn't seeing anything over the duel nozzle set up Ash?
  35. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Hi mate,
    No update on this I’m afraid. I’ve put it on the back burning now I’m going in a whole new direction! I’ll get to the bottom of it, but chances are I just need to run 80/20 meth instead of 50/50. Maybe look into the timing of when the meth is engaged as well, moving the solenoid closer, etc.
  36. S3AMJ
    S3AMJ OEM+
    2,198
    786
    So some updates on the build
    Engine on its way out on the S3, didn’t take long!
    And...... it’s out! So my Built S3 is now gone to its new home in an Audi TT. It was completely stripped to bare engine and I swapped out the rocker covers as I’m keeping my AGN rocker cover.
    Next in line was the A3 Stroker, front off.....
    And shortly after.......
    My new S3 engine out and ready to be pulled apart to get it to the next level!
    Then stripped all the parts off the A3 and S3 that I won’t be using ready to be sold! I will list them all with some pictures in the next week when I get time.
    Goodbye A3 you have served a purpose, shame see it go, very clean car for its age.
    craigt1985, Asim1, hydro s3 and 2 others like this.
  37. Brad1011
    187
    57
    LETS GOOO!!!
    Started on mine today took of my first wishbone felt like a trophy in the p*ssing rain
    S3AMJ likes this.
  38. S3AMJ
    S3AMJ OEM+
    2,198
    786
    Small update today guys....
    I’ve taken delivery of my CAE Shifter this morning, looks amazing, awesome build quality and surprisingly light weight!
    The one I’ve bought is the under mounted one, which means that it’ll use the original positioning of the cables. The other version which mounts inside the car you have to drill into the bulkhead to feed the cables.
    Hopefully this will be OEM+ rather than race car as I want to retain most of my interior.
    I bought the additional metal bracket for holding the new CAE HD cables and the counter weight adjustable thingy which attaches the cables to the gearbox.
  39. Brad1011
    187
    57
    LESS INTERIOR = MORE HORSES
    S3AMJ likes this.
  40. S3AMJ
    S3AMJ OEM+
    2,198
    786
    If I get my goal BHP mate.... some interior will be alright haha, just going down the route of my half cage and bucket seats so that’ll save a load of weight!
  41. Brad1011
    187
    57
    I think you should opt for the recaro pole positions if you’re going this far. They are mustard!
  42. S3AMJ
    S3AMJ OEM+
    2,198
    786
    I do like the pole positions to be fair..... but I have been told by many that they are really uncomfortable. So I’m still looking at my options
  43. hydro s3
    hydro s3 S3 amk
    1,363
    410
    Are you planning to just do a few track days or something the same as Prawn racing has gone for?
