  2. Dismiss Notice
My Belated build thread
S3AMJ May 20, 2018
  1. Tj 0785
    Tj 0785 Registered User Bronze Supporter Silver Supporter VCDS Map User
    3,877
    1,185
    Go on get your name on the turbo haha, @S3AMJ
    if your breaking the a3 shell I need a decent bonnet
    S3AMJ likes this.
  2. Avatar
    snack-media
    Advertisement
  3. S3AMJ
    S3AMJ OEM+
    2,200
    786
    After doing further research into this build and having spoke to Bill about it a few days ago. The turbo kit that is currently on it is a Pagparts bottom mount manifold with a GT3071r 0.63 V3 Billet comp wheel Dual ball bearing with V-Band hotside.
    I've not really heard of Pagparts before until now and apparently in the US they rave about this Billet comp wheel upgrade. This turbo is rated at around 450-460whp this is around 540bhp with a better response than a standard Garrett GT3071r... apparently capable of full boost at 3800-4000rpm and holding power all the way up to 7800-8000rpm. This does depend on all the other supporting mods of course.
    Obviously need to fully inspect the car and all its parts condition. I'm thinking of getting a Nortech 1.5" manifold and using this turbo, but future proofing so if and when I decide to change the turbo it should be just a straight swap out.
    Asim1 and Tj 0785 like this.
  4. hydro s3
    hydro s3 S3 amk
    1,365
    410
    Very nice buy mate. Did you find out ur wmi issue?
    Id be interested in the vibra-engine mounts when you come to sell them.
  5. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Thanks mate, it was a no brainer getting it nah not got to the bottom of it, going to try different ratio of water/meth and doing some logging. Yeah sure I’ll let you know about the mounts, just need to double check. The gearbox mount is the same for your car.
    hydro s3 likes this.
  6. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Went to see Badger5 at the weekend to have a catch up and see a Stroker Octavia G25-660 get meth’d up on the dyno. With some impressive results!
    Couple of pictures of my cars side by side, almost like the dark knight / knight in shining armour thing going on.
    After further discussions and planning..... Going to be breaking the A3 and keeping the stroker engine and oil cooler. Everything else will go up for sale, which I’ll post up on the forum and eBay once they come off the car sometime in September.
    With that said, I’ll be going Nortech top mount, 44-45mm wastegate and probably G30-770, having looked at compressor maps and no one having used this turbo yet on the 1.8t 20v (stroker) I’m kinda thinking go big or go home
    Shopping list....
    G30-770 Turbo
    Nortech 1.5” Top Mount Exhaust Manifold
    44-45mm Turbosmart External Wastegate
    3” Downpipe
    Fluid Dampener
    1000cc Bosch Injectors
    Forge Supersized Recirculating Valve
    Gearbox (uprated)
    Should see me north of 600bhp all being well.
    Here are a couple compressor maps for anyone to look at, Garrett have a “Boost advisor” where by you input all the info and it generates a list of suitable turbos to run on the car.
    My goals I’ve inputted were 650bhp on pump fuel with the 2L stroker engine.
    This is the G30-770 @ 30psi compressor map, which seems very suitable for my setup, sitting perfectly in max efficiency.
    This is how the G25-660 compares, all the same info running @ 30psi.
    As you can see the G25-660 would have to work extremely hard to achieve 650bhp and be way out of it’s max efficiency. Generating masses of heat which is how I read the compressor map.
    I’m a novice when it comes to turbos and reading compressor maps, so I’m open to opinions good or bad.
    Asim1, hydro s3 and Tj 0785 like this.
  7. Tj 0785
    3,877
    1,185
    When you hoping for it to be back on the road in g30 mode? Let me know if you find them at a good price anywhere,
    what wastegate is on the a3 now? Mia the a3 boot panels the same as in the s3?
  8. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Not sure mate, I’d like to think mid October. I’d be buying everything through Badger5 mate to be honest. The wastegate that’s on the A3 is a Turbosmart 38mm I believe.
    When you say boot panels, which do you mean? The inside boot panels?
  9. Tj 0785
    3,877
    1,185
    Put me down for the wastegate aswell as the brembos then,
    Yeah the inside boot lip and the two sides that cover the amp and lights
  10. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Sorry mate, Things have changed slightly on the brembo’s. I’m gonna keep them and sell the K-Sports. As for the wastegate, now that I’m ditching the idea of keeping the original GT3071r turbo and going G30-770. I’m gonna sell then turbo as a complete setup. So the wastegate will be sold with the turbo, manifold and downpipe.
    I’d need to have a look and see if those panels are the same as the S3 I’ll let you know when I’m next there.
  11. Tj 0785
    3,877
    1,185
    Are they k sports any good ? I just looked a badger5 probably where il get mine from with the ecu
    S3AMJ likes this.
  12. Avatar
    snack-media
    Advertisement
  13. S3AMJ
    S3AMJ OEM+
    2,200
    786
    The K-sport are fine plenty of stopping power and they are bigger discs. Just more maintenance costs, replacement discs and pads are quite expensive. The brembo’s will do fine for what I need them for, easier to swap out pads for track days and for road use.
    What you have to remember mate is Badger5 are very competitive with prices but it’s the customer service you want. Bill and his team has always been very supportive. A service that you are not always likely to get anywhere else. That’s why Badger5 has such a good reputation.
    Tj 0785 likes this.
  14. Tj 0785
    3,877
    1,185
    Yeah that’s true I didn’t see the g30 990 on the but I’d imagine he will be able to get it if I go for that over the 770, don’t see the dw65 fuel pump anymore either, pm me what you’d be wanting for the k sports I love the look of the 18z but the more I read the less confident I am I’d be happy with the pedal travel
  15. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Badger5 are a Garrett supplier so he would be able to get anything you wanted I’m sure.
    You’ll probably be looking at external swirl pot setup for your build, something I’m gonna have to consider for mine as well potentially.
    Best thing to do with the braking side of things it’s lots of research, I don’t know what the travel is like on the 18z brembo’s, they are a big caliper for sure. The K-Sports would have been made to run correctly for what car you buy then for.
    Tj 0785 likes this.
  16. Tj 0785
    3,877
    1,185
    Yeah its the big piston size on the 18z that makes the pedal feel bad, obviously they weren’t designed for our cars and others with them have tried using different master cylinder but seems a lot of effort so On the look out For a decent set as a back up , beat me in mind when they going up for sale
    S3AMJ likes this.
  17. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Will do bud
  18. Tj 0785
    3,877
    1,185
    never thought about that was thinking a dw65 and a line pump aswell but will look Into it
  19. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,364
    5,601
    I have a DW65 and an 044 inline... that supported 620hp with overhead... swirl pot is a decent thing to have for reassurance but not entirely required for the power level...
    I may well have gone down that route at some point tbh but don't let it get in the way of the rest of the build...
    You will want to use teflon lines for the internal runs... and ideally firewall off the swirl pot/pumps etc
    S3AMJ and Tj 0785 like this.
  20. hydro s3
    hydro s3 S3 amk
    1,365
    410
    That's a excellent way ur taking the car now. 650hp the thing will be a rocket going up the road.
  21. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Thanks mate, see what happens but that’s my goal now getting that A3 just made it happen sooner, was meant to be buying a house end of this year. With all this Covid stuff going on, I’m putting that on hold until next year now. 650bhp would be scary fast! I’m still going to running loads of water/meth and NA cams..... who knows where that G30-770 will land me.
  22. Tj 0785
    3,877
    1,185
    You thought about the badger5 cams?
  23. S3AMJ
    S3AMJ OEM+
    2,200
    786
    I have toyed with the idea of the badger spec cams, as seen they do change a big turbo build dramatically 100bhp+ But as I have a set of NA cams which would certainly help a big turbo build I’ll use them and see what happens. Be a good experiment to see what they do just dropping them in.
  24. hendo#1
    hendo#1 Registered User
    354
    132
    43
    I sold my S3 over a year ago now but still pop in here occasionally.
    Initially we were both kind of on a similar path as eachother with the hybrid set-ups etc.
    I remember seeing that A3 for sale on here originally and thinking it was a bargain.
    Really enjoying watching how you progress this, keep up the good work.
    S3AMJ likes this.
  25. S3AMJ
    S3AMJ OEM+
    2,200
    786
    I’ve been trying to find a build thread on this car, I’m assuming Neil (owner) never did one.
    Good to see your still around bud, I remember we were discussing stuff about the hybrids, etc.
    Stay in touch
  26. Tj 0785
    3,877
    1,185
    What do you drive now, do you miss the s3
  27. hendo#1
    354
    132
    43
    Finally got myself the V8 BMW M3 I’d been promising myself for the last 3 years.
    I do miss the S3 sometimes, I learnt a lot from it and enjoyed constantly upgrading and spannering on it.
    Everytime I log in on here I hope to see it pop up with a thread. Although it failed its last MOT on “excessive exhaust smoke at idle” which isnt a good sign.
    The M3 is more suited to what I want from a car now though.
  28. badger5
    10,216
    2,380
    For ref, Badgerwagen on its G25-660 on 34psi boost did 565bhp a few weeks ago. on its 1.9 engine
    S3AMJ likes this.
  29. S3AMJ
    S3AMJ OEM+
    2,200
    786
    I think Garrett base there max turbo figures on running them with E85 fuel and larger displacement. Obviously something we can’t really get our hands on over here. Not to mention they tend to be DYNO happy in the states.
    Your Badgerwagon Bill is probably the best we would expect from the G25-660. Be interesting to see what it would do on a 3.2......
  30. <tuffty/>
    24,364
    5,601
    I had a go with the boost adviser...
    Not surprised at the recommendation but boost levels are interesting... considering I planned to run my vanilla GT3582r at 1 bar... this was using pump gas option too
  31. <tuffty/>
    24,364
    5,601
    ....also worth noting that boost values are also subject to flow restrictions in the charge air system so you may well need a little more boost to reach the airflow required to achieve these results...
    S3AMJ likes this.
  32. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Would be good to see how the “Boost advisor” compares to real world figures. I know there are loads of variables..... but still.
    Got my list together of the things I needs to buy. Will be getting it all from Badger5. I think the turbo will be the first thing to order as there’s quite a lead time looking at Badger5 website. Need a chat with the main man to get the ball rolling
  33. Avatar
    snack-media
    Advertisement
  34. hydro s3
    hydro s3 S3 amk
    1,365
    410
    That's good news on the bt build your not hanging around. How long is the lead time for the turbo you want?
  35. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Once I’ve got something in my head mate I go for it. It’s just getting my ducks all in a line. Selling stuff, taking things apart, so on and so on.
    The turbo is a G30-770 which has a lead time of around 21 days at the moment. So if I order that next week..... should come in time for all the other things to happen. I do need to get my gearbox or a gearbox built to take the pain the engines going to be throwing at it. Just waiting on a quote from Gas&Gears.
    Badger5 (Bill) has been kind enough to store my A3, I’ve already sold my engine that’s currently sat in my S3...... just a case of organising and being prepared so the swap goes as smoothly for then as possible for them.
  36. hydro s3
    hydro s3 S3 amk
    1,365
    410
    That's good progress mate.
    There is a guy on fb a big turbo 20vt page and he is selling a 2"nortec v-band manifold if it of any interest to you
    S3AMJ likes this.
  37. S3AMJ
    S3AMJ OEM+
    2,200
    786
    2”?!? That’s massive.... I think Badger5 has either 1.25” and 1.5” Nortech manifolds.
    What’s he after for it? Might be overkill even for my set up.
  38. <tuffty/>
    24,364
    5,601
    Don't bother with 2"...
    1.5" is more than enough for 600hp and low EGT's...
  39. S3AMJ
    S3AMJ OEM+
    2,200
    786
    What would you need 2” for anyway? That’s gonna slow velocity down a fair bit I’d imagine. What is 1.5” good for anyway? I know it’s 600Bhp+
  40. <tuffty/>
    24,364
    5,601
    Couldn't tell you for sure... but given Bill has plenty of cars out there making over 500hp in 1.25" runners and I made 620hp in 1.5" with decent EGT's you can read into that what you will... I suspect its more power than most 20v builds could handle :)
    S3AMJ likes this.
  41. S3AMJ
    S3AMJ OEM+
    2,200
    786
    Probably a 2.1 stroker running a G35-900 or something @ 40psi haha....
    I’ll be going with the 1.5” but thank you Hydro for thinking of me
  42. hydro s3
    hydro s3 S3 amk
    1,365
    410
    No problem mate.
    He was looking £600 for it not sure if that's good or not.
    S3AMJ likes this.
  43. <tuffty/>
    24,364
    5,601
    2" is huge... not much room with 1.5" but none with 2"... have done a car with a 2" before.... IIRC he ended up with one of Bill's 1.5" in the end
    hydro s3 and S3AMJ like this.
