You seem to know your stuff. In what part of the world you are based ?
2006 Audi A6 3.0TDI quattro sline le mans | Daytona Grey Pearl
Darlington
I'm sure I've read somewhere that there are issues with the RS6. The software on the MMI 3GP units are from the Q7 model, as that is the only one that is compatible with the C6 range, air suspension does work, but the DRC suspension was never an option on the Q7, so I don't believe the software is there to control the DRC system. If you have VCDS then you may be able to change the setting, but not the best of workarounds.
SD Card slots
Higher resolution screen
DVD playback using the inbuilt DVD drive, and full control of the playback
Hard disk for storage of Maps and music (Optional)
SD Card slots
Sim card slot (optional)
AMI Inbuilt into the Main MMI module only a cable is required much cheaper than the 2G option.
Telephone inbuilt into the main MMI module. Only need the microphone, so a lot cheaper that the 2G retrofit
MMI 3G firmware is still being updated by Audi
Full postcode possible but needs a special firmware update.
Latest MAPs and firmware available FOC if you dig around for the information
3D maps also look very cool...
I'm also going to be looking at 3G+ Update which would require replacing the 5F unit, that would give the very latest MMI interface and you can play movies VIA the SD cards
Hi, I can help. I like and the procedure for conversion of units from 3gp mmi audi a8 in Q7?There is no C6 option in MMI 3GP, to make the 3GP system compatible with the C6 range you have to run the Q7 software as that uses the same can-gateway protocols & speeds as the C6. C7 units are not compatible as they use different high speed can gateway protocols.
Sorry I just don't have time at the moment, preparing my old A4 B5 for sale, working on the house & looking after a 2 year old... should have some time once my C7 has been delivered & my old A4 B5 next month..
Sorry don't have the wiring diagrams to hand at the moment, but I think you just need to supply 12v to the lights.
