todays update... had quite a productive day.
i fitted my water meth kit!
tank and pump fixed in the boot, the pump is earthed in the boot also.
fiddling with wires to get it all wired up.
this is where i pulled all the cables and pipes through, its the same place i run the vac line for my boost gauge.
mounted my solenoid. (the lighter was for putting the shrink wrap around my solder joins and to start my gas soldering iron.. not because iv started to smoke again.. for those that have seen my stopping smoking threrad)
did a test to check my wiring was all good!
messy wires... at least no one can see them!
when i was putting the boost switch inside the dash it touched with the chassis and sorted causing it to blow the 15 amp fuse for head light switch. i decided to move it as this way i can also slip the quick fixings off if i don't want to run water meth, this is where it is located now its in the little cubby hole under the head light switch. the boost switch is set to 12psi.
injector nozzle tapped in to the hard pipe just after the FMIC and before the TB. i have also put some epoxy metal on there as well.
that's about it for today lol i did pick some deironised water up and some methanol.
i got my methanol from
Simpson Racing Products/Services
i got 25 litres for 20 pounds. 99.95% virgin grade.
the guy was awesome he was well impressed with my car, even took a look around. said he would like to know if it makes a big difference. he also said that alot of people have been going to him in scoobys because they are running there scoobys on 20% methanol 80% petrol lol these must be these scoobys i see that lick 1-2 foot flames and go like stink.
