- Joined
- Dec 2, 2008
- Messages
- 17,400
- Reaction score
- 1,104
- Points
- 113
Looking forward to this as mine will be at RTech in 2 weeks time and I might only be gaining 10bhp lol. It's all about the delivery and drivability of the car.
hahahahahahahahahahahahahahahaha.
Oh my word, 150 - 280bhp? in one step? that's AMAZING! id be pretty confident saying you have no idea what's coming
Awesome stuff! can't wait for your report!
can I have my 4bar back when you're done Westicles? Just incase I need it when mine's tweaked.
just read through your whole thread, just amazed that someone on similar money to me has enough to do all of this i find myself spending every penny I have each month, maybe I should consider getting a bit more serious about the car build just going about it as a daily even tho I have a work van so car is only used to ferry me from friends and gfs houses and shops and what not.
I might have to follow your lead on the hybrid turbo seems to be good. I may be in touch with Dan shortly.
big yes to WMI I love mine. makes the flames blue instead of yellow too!
fire cat:
brilliant right up mate,just spent an hour reading through the whole thread. Wish I had the funds to do this work to my motor, great thread and write up. Any pics of finished project?
ALex
Did you run with the Fmic that I saw on the 1st page? What pipe work size did younrun as well?
Im just wondering if running the Welly cooler would make difference .
Awesome, im aiming for 260 ish from my quattro, its an AGU, KO4 turbo, FMIC, BAM injectors, De-cat, large TIP, 3in vr6 maf housing, and a re map, think thats everything
After reading this thread i now dont want to wait i wanna start fitting it now
Yeah man you should see more than 260 out of it with a k04 on it.
You should take a look at westys build thread, he's hoping to get 300 out of his k04, you will need rods for this, rifle drilled ones if you get some.
Dont use BAM injectors. They won't fit for a start, then when you make them fit, they won't work very well.
Also, a Quattro with an AGU?
What injectors do you recommend mate?
Ok sorry will bring this up to speed, my car is a 2001 Y plate 5dr quattro, a customer at work owned it and didnt bother having it serviced, his Oil pick up blocked, the cam sensor melted as did the chain tensioner, the inlet cam siezed in the head, so he was gonna scrap it, i offered him a little more than scrap money and he took it, so my plan was to fit another engine and flog it on, so i picked up a good AGU locally mega cheap that i knew a little about (know how the ex owner drove) so i changed the lump and test drove it, now i must say at this point i had driven it at work a few times but as it wasnt mine i didnt give it any stick, so on my test drive i kicked it big time and wanted to keep it (i own 3 diesel vws so the audi went like a rocket) anyway the KO3s was little smokey and didnt seem to hold boost that well, i was gonna just fit a new one but then knew id get bored of the power in no time so have decided to ko4 it, looking for about 260 (anymore would be awesome) so that explains a quattro with an AGU fitted (i know i should have replaced it with an ARY but at the time i was just gonna flog it on and didnt wanna pay the £700 odd i saw them up for)
so any pointers on injectors and anything else i will need would be perfect
260 on a ko4 is EEEEAAAASSSSSYYYYy mate
what injectors you need will be down to the inlet manifold you're running, and the ECU. being a 2001 I'd guess it's DBW and wide band? if so the BAM injectors will work. if it's on ME3.8 with a cable throttle you'll need something like the saab reds.
Thank you Prawn
now when i fitted the AGU i used the ARY inlet manifold complete, yes mine is DBW, so will the BAM injectors fit, and will they give enough full when its mapped? ****** i bid on some saab reds last night
Doh! you didn't say you had swapped the inlet mani over lol
so to get everything right you have an AGU block and head with the management of the ARY with the inlet of the ARY lol its like a car parts pick and mix. at least you've got the better of the blocks and heads with the better management.
