Mpg 8l
garym_s3
Hi guys after some help.
I've not long got a 8l apy engine code , running an mrc map. Approx 250bhp. What would you expect to get mpg wise? I'm currently getting 23/24 ish, now I only use it evening and weekends and not many motorway miles. Just curious to see if that is normal
I'm getting about 27 with a b5 tip and remap, I drive on A and B roads. If I were you I'd expect a bit more but your not far off the mark
I have a APY myself and with normal driving I'm around 28/29. When I boot it everywhere it's around 24. Most of my driving is on A roads. I'm guessing a lot of your trips are in densely populated areas, if that's the case then 24ish sounds about right
Must be only me gets 10mpg around town . Been try to tackle it but no luck
Short term fuel term does this look normal
God knows from that... probably not the best block to log... if you are getting poor MPG then there are other things amiss
Log block 031 for starters as yours is a BAM then see what AFR is... also need to try block 001 to see what coolant temp is doing and also what corrections lambda contol is having to do... you should check block 032 to see what long fuel trims are like
Scan for fault codes to see if there are lambda or EGT codes
<tuffty/>
No codes at all i will log what u said
529
16
13
23
