  2. Dismiss Notice
Motorway mode
Devilz Jul 23, 2017
  1. Devilz
    Devilz Active Member VCDS Map User
    440
    128
    43
    I was browsing through some german forums today and came across this. It was listed under Q5 mods but I tried on my 2012 A6 and coding was accepted. Didn't had chance to test it yet. Anyone else done this or can confirm if this actually works.
    Motorway mode takes advantage of the large amount of light and optimized lateral and apron lighting of the xenon plus pig launcher. About sensors, a vehicle electronics analyzed continuously the speed of the vehicle. After a short time above 110 km / h, the system is based on a highway driving and automatically switches from the low-beam mode in motorway light mode. Due to a special position of the aperture in the xenon headlights plus additional light is then focused by an aluminum reflector and far in front of the vehicle is thrown but without dazzling other road users. The sight is more than doubled: from 70m in low-beam mode to 150m motorway light mode. This increase in visibility means to respond to objects in front of the vehicle at a speed of 130 km / h has a gain of 2 seconds. so Motorway mode increases driving safety significantly.
    The following coding applies:
    Select Cent. Elec. - 09
    Coding 07
    From Drop down menu Select 2 - xxx - RLS (rain and light sensor)
    byte 0
    Bit 0 - motorway light - Activate
    Santoku likes this.
  2. Avatar
    snack-media
    Advertisement
  3. DeanoC
    DeanoC Well-Known Member VCDS Map User
    840
    838
    93
    I've activated this on all my audis. Works well
  4. Rhyso
    Rhyso Registered User
    1,818
    487
    I've activated it but reading the text it only applies to the Xenon Plus headlights which have the high beam assist??
    In my VCDS is states 90mph and above!
  5. DeanoC
    840
    838
    93
    Yep 90mph. You can see them move up on signs
  6. Rhyso
    1,818
    487
    Do you have the high beam assist?
    Or just standard xenons?
    Mine are standard so I don't think this will work even though it's been enabled
  7. DeanoC
    840
    838
    93
    Adaptive xenons. No high beam assist
  8. SirTT
    SirTT Registered User
    49
    :grinning:I need to activate my pig launcher, that sounds ace.
    GavG likes this.
  9. Devilz
    440
    128
    43
    It worked...
  10. SirTT
    49
    We need pictures...:yahoo:
  11. Devilz
    440
    128
    43
    Sorry I can't take pictures while driving
  12. Avatar
    snack-media
    Advertisement
  13. SirTT
    49
  14. Rhyso
    1,818
    487
    @Devilz do you have standard or the adaptive xenons?
  15. Devilz
    440
    128
    43
    Standard
    Rhyso likes this.
  16. Rhyso
    1,818
    487
    Do you have to flick the stalk to activate or simply drive at the required speed?
  17. Devilz
    440
    128
    43
    Just drive buddy
    Sent from my SM-G955F using Tapatalk
    Rhyso likes this.
