If the pump is OK and the jets are clear you should get instant spray.I find the jets awkward to get to and adjust but no doubt the system could do with a clean but too fiddly for the little use mine get
If you fit a little one way valve just before Y-spliter for jets, then I'd imagine it would fix the issue. Could even get away with using a generic PCV valve, at a push.
