Hi all,
Just wondering if it would be ok/safe to change the intake and exhaust but still run a stock ECU map, my guess is that it should be ok as the air flow meter should adjust the fueling and timing as per the airflow.
I will be completing my project car in stages and will probably look to do a few drag runs in various states of tune from bone stock to forged engine - will be interesting to see what difference it makes for each mod. I will initially be running the car in stock form but might take an aftermarket air filter with me to swap over at the track and do back to back runs to see what happens with the time.
I just need to check if changing over some basic hardware eg intake and exhaust is still fine on a stock ECU map, ideally I would port the wastegate as well to avoid boost creep as well. I don't plan to touch the boost level when everything is standard but might fit a EBC to maintain a steady stock boost level.
