mmi removal key
Dusty Des
300bhp tfsi
Looked every where and cant find out what the radio/mmi removal key looks like.
Anyone got a pic or link please.
A5 2017 B9 unit in glove box
S32B
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
you have linked these, which are incorrect:
CT22AU02 new 1000x1000h
Need these:
Ct22au01 1 1000x1000h
Need to remove glovebox in order to remove the MMI also.
S32B
I went to the main site and put the year and model in, sent me to those!!
Dusty Des
300bhp tfsi
Well that was a bit of a waste of time. The keys are as DJAlex said but you cant pull the mmi out as cables are too tight. You cant use keys with glove box in place as it covers the slots (one hidden screw inside at an angle on right hand side not easy to see). You need to drop down the mmi (2 screws, 1 plastic pin) then unplug so you dont need keys for the job.
Thanks for help all.
DJAlix
Site Sponsor
Gold Supporter
Remove glove box then use keys to release and slide the MMI unit forwards a little. Once loose you have access to the rear of the unit and some space with which to remove the cables while the MMI is still in its holder / cage. Once cables are released then you slide the MMI unit out.
