MMI GPS Clock Change
6EGA3
Surrey
....didn't appear to work this morning. Anyone else have the same issue or does it take a while to recognise that the clocks have gone back?
You can set Daylight Time Saving in the settings and it’ll calculate using the correct date.
My PFL changed this morning.
Just make sure “Manual change” is switched to off in the MMI
Well mine is a PFL and I am sure it changed in March. I had a look and it's set to GPS time and the timezone is set to UTC. Weird.
If you search the forum you will see a large number of people reporting the lack of automatic change within PFL vehicles. Maybe your vehicles have been coded. Is Europe available as an option within your MMI setting?
I’m from the UK. There are several setting you have to select. Like GPS “Manual adjust” off.
Will get some photos later.
I just discovered the manual summertime setting which was set to On. I guess that's it.
Reactions: Phil-1
The auto change has never worked (its a PFL), I need to toggle the summertime setting on and off in the MMI to get it to change the time. It does know where I am (Sydney).
Yeah I had to change setting to off this morning to adjust time on my PFL
55
189K
15
11K
881
D
50
4K
