  2. Dismiss Notice
Facelift MMI firmware update
Adam sielski Mar 30, 2020
  1. Adam sielski
    Adam sielski Registered User
    60
    So, I’ve been looking into upgrading my firmware on my mmi. I have a A4 2017 model and the media drivers are; clu6_mcm_au_er_g21_042...
    The only problem is that I’m sure the screen is too small for the whole number for the firmware.
    Has anyone updated theirs and other than asking Audi to upgrade ( even though it’s like getting blood from a stone asking them ) is there another way?
    Thank you in advance
  2. Avatar
    snack-media
    Advertisement
  3. Evil Derboy
    Evil Derboy Registered User
    957
    932
    93
    I’ve done it for the MMI and VC. The firmware is available to download online (don’t ask me where or for links.)
    It’s a simple transfer to SD job and the. Plug in and go.
    in truth unless you’re suffering from stability issues there is very little point in doing it. The changes are minuscule to the point that unless they were pointed out to you, you’d probably not even notice.
  4. Adam sielski
    60
    Ahhh, ok. I was mainly wanting it so I can activate the WiFi Apple CarPlay but I’ll just stick to map updates
  5. rasA4
    rasA4 Four Rings Mafia Specialist
    3,781
    306
    WiFi Apple CarPlay? Is this available for your 2017 car?
  6. Adam sielski
    60
    The options for it to be turned on are there, including the 5ghz switch. I wouldn’t see why it isn’t
  7. cuke2u
    cuke2u Well-Known Member
    12,899
    5,234
    Just because there is an option to turn it on, you don't state with what, means diddly squat with Audi. You will be unlikely to get any support from them either. If you want advice with any aftermarket stuff then AS member @DJAlix is your man...
  8. DJAlix
    DJAlix VAG Car Coding™ Limited Site Sponsor Gold Supporter VCDS Map User VAG Can Professional ODIS (Offboard Diagnostic System)
    6,285
    4,804
    Settings are indeed there but your MIB2 system does not support wireless CarPlay, its an MIB2.5plus onwards feature.
    cuke2u likes this.
  9. Adam sielski
    60
    Cheers guys, Thanks for all your info I might start looking back into it when all the other stuff has died down
  10. Kondax
    Kondax Well-Known Member Gold Supporter
    825
    275
    Do you know if it would be possible to fit the newer MIB systems into the early B9s?
  11. cuke2u
    12,899
    5,234
    I guess anything is possible if you've a bottomless wallet. The main MMI unit would need to be replaced, the display, the virtual cockpit, possibly the wiring and parts of the dashboard. Then you would need to code it back to Audi...
  12. Avatar
    snack-media
    Advertisement
  13. Kondax
    825
    275
    My question was less about whether you could physically replace the entire dashboard of the car and more about the compatibility between the two MIBs, if they shared any common hardware, etc. Given Alix's knowledge of the cars I thought he would have some idea as to what would need changing.
    I do agree though, probably the MMI unit, screen and VC at a minimum.
  14. cuke2u
    12,899
    5,234
    The hardware is different from our cars to a 2020 model, which is the reason why the google overlay will be disappearing from ours soon.
    I guess you mean @DJAlix
  15. Kondax
    825
    275
    Yes, of course. Just because they have changed the GPU it doesn't mean they've refreshed the entire architecture of the MMI system.
  16. cuke2u
    12,899
    5,234
    It's touchscreen for a start, the whole OS would have to be changed or re-coded, perhaps they are no longer using QNX. It has OTA updates. I don't know we seem to be arguing the same points really. As you state, if anyone knows it is @DJAlix if he has stripped one back...
    Kondax likes this.
  17. Kondax
    825
    275
    Not necessarily, I highly doubt they have reworked the entire MMI OS from the ground up. The touchscreen is just a different input device, it wouldn't have been difficult for them to integrate that into their current software. It's more likely just reskinned, it won't have meant reprogramming the entire OS.
  18. DJAlix
    6,285
    4,804
    Not had a reason to test this as yet but my guess is that fitting an MIB2.5plus in to an older platform vehicle will not work without issues. A missing touch panel may be one such issue but I can bench golf MIB units with Audi screens and controls at the moment so not 100% sure. The biggest will be the screen itself as the current range of MIB2 displays will not support the resolution of the new units, this and the screens in question are also way larger so physical fitment will be an issue unless your happy with gaffer tape on your dash :)
    Edit: the OS is still QNX
    tickedon and Kondax like this.
  19. Kondax
    825
    275
    Already got a load of **** in the car, some gaffer tape wouldn't hurt! Thanks for the response, seems about right :)
    I'll have to wait and see what you come up with. Hoping to keep the car for a few years, wouldn't mind the new screen. Although saying that, I absolutely hate the VC. Who knows.
