HelloSorry, you are wrong. First you have to understand how the MMI-Screen works with the LVDS connection and then how to interpose (an android) in that connection and how the android processes the image.
In my case, the link that you have put up, the MMI is the basic, the original LVDS cable that leaves the MMI to the screen, connects to the android, where a specialized 1024 (HD) chip is responsible for reprocessing the outgoing image Of the MMI and send it by another new LVDS cable to the new screen, which has 1024 resolution. Nothing to do with the original screen that Audi, either the 5.8 "or the 7"
The android chip, is independent of the operating system, works in parallel. That is, I can hang / break the android OS, and the MMI image will still work perfectly.
That said, the chip re-scans with interpolation the images, but they do not look with sawtooth or pixelated as I think it has been said, if they do not look much better quality menus. Just see the song covers. The only thing that seems not very successful, is the text of the menus, but that is by the type of source that Audi has chosen to visualize.
However, in my profile of the mentioned forum, you have images and videos of the android performance. If you put the images to full screen or videos, and 1080 on youtube you will see the quality it has.
The images uploaded to the forum, are reduced of quality so that they occupy little. If anyone wants good resolution images, they will be delighted. Or videos or whatever you need.
regards!
There seems to be an issue with your CAPS Lock keyHI ! I WILL BE THANKFUL IF YOU HELP ME WITH MY VEHICLE AUDI A3 8V SPORTSBACK 1.6 TDI ULTRA.I HAVE THIS PROBLEM ONLY WITH THE AUDI MENU RESOLUTION DISPLAY,EITHER SPECIFIC MODE OR FACTOR SETTING I HAVE TRIED IS THAT RESULT.I THINK THE RESOLUTION IT COMES OUT FROM MY HEAD UNIT 400*234 TO THE ORIG MONITOR 5.8 INCH IS THE PROBLEM.MY NEW MONITOR IS 8.8 INCH ,RESUL.1280*480
HOW CAN I FIX IT?THANK YOU
thanks you! i like writing with CAPS...sorry for my english spelling.... older i had a nanitouch android with 7'' screen... and the display of audi factory was ok ! there is no way? with lvds cable or any adaptor,converter,interface to sent from mmi unit lvds out to lvds monitor a better signal,resulution image??or is the SW, like rizzy said? thank you anyway!!There seems to be an issue with your CAPS Lock key
MIB1 Standard Units support 5.8" screen only.
MIB1 High Units support 7" Screen only.
MIB2 Units, any Audi A3 type, support 7" Screen 0nly.
pou meneis?τhank you for your reply, i am a beginer at forums!! thanks you anyway! here in greece all the salesmen tells me to send the mmi unit....only the mmi head unit to china to fix it.???every posible solution is welcome....
Ι am trying to achieve normal image of factory menu(not double or half-cutted),cause my android,apps,google,gps looks and works perfectly and also the sound. its a matter of lvds cable line signal(or mmi sw signal) from mmi unit to android chinese rubbish.I dont think i can do it even with vcds 15.07.01 i have. All the settings on the chinese android screen doesn't change anything, only maybe an update,when chinese do so.except if someone good technician help.Othewise i'll live with it.pou meneis?
What are you trying to achieve? Just a larger screen / display or do you want Apple CarPlay and Android Auto etc?
I visit Athens, Lamia and Kavala regulari am living near chalkis city(chalkida)
VOG-L2
ok!I visit Athens, Lamia and Kavala regular
Message sent@DJAlix
I am really sorry to hijack this thread.
I have tried to contact you through vagcarcoding.com but unfortunately I had no reply.
I am a new member here and can not start a PM. Would it be to much trouble for you to send me a PM so we can take it from there?
