Hi I just bought a6 c6 2006 with mmi, idk is 2g or 3g I have cd changer but I want to get some bluetooth module, here what I have. Is there some cheap option for bluetooth? Sent from my CLT-L29 using Tapatalk
You have the 2g mmi as your car is a pre facelift (~2009 when the facelift happened). It also looks like you don't have the AMI port either which limits your options. You can either get the AMI port retrofitted and buy an adapter like tune2air. Or get a Bluetooth/FM transmitter and use the radio to receive it. You might be able to swap the cd changer out but I don't know if that's possible. Someone else may know more on this. Sent from my Pixel 2 XL using Tapatalk
Yes I think the only way you can get Bluetooth audio is to buy the AMI module, then get a Bluetooth receiver that plugs into an aux input. Its a more involved/more expensive operation than on a facelift 3G model. This might help: https://www.a6retrofits.com/ami-retrofit-audi-music-interface-a6-4f/ Sent from my SM-N960F using Tapatalk
