  2. Server Issues - 21/07/18
    Please accept our apologies for difficulties you may be experiencing using the site this afternoon.
    We are aware of a technical issue and are working to resolve it. There may be more brief outages this afternoon. We will aim to keep disruption to a minimum, but unfortunately some is inevitable in order to resolve the issue with minimum delay.
    Thanks for your patience.
    ASN Admin
    Dismiss Notice
Q7 MMI 2G (Bose) Broken - Blank Screen - VCDS Scanned, Please Help!
Fahd Jun 20, 2018
  1. Fahd
    Fahd Member
    39
    Hey guys,
    Having some serious issues with my MMI 2G (Bose system) and would appreciate some advice in troubleshooting to get this fixed as know a number of people on here are pros in this -
    Issue:
    1) MMI Screen is completely blank, does not turn on.
    2) The MMI centre console buttons near the gear shifter don't light up/ do nothing, speakers/ radio aren't even turning on.
    3) Given the above, I cannot go through the standard MMI button reboot (holding setup, control knob and top right button).
    4) As MMI doesn't turn on I have no radio, bluetooth, no sat nav, no control over suspension height etc.
    Full VCDS scan as below:
    Chassis Type: 4L0
    Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 18 19 34 36 37 42 46 47
    4F 52 55 56 57 61 62 6C 6D 6F 72 76 77
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    06-Seat Mem. Pass -- Status: Malfunction 0010
    07-Control Head -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    34-Level Control -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Cannot be reached 1100
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 1100
    57-TV Tuner -- Status: Cannot be reached 1100
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    6F-Centr. Conv. II -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4L0 910 401 M HW: 4L0 907 401
    Component: 3.0L V6TDI G000AG 0030
    Revision: --H04--- Serial number:
    Coding: 0011775
    Shop #: WSC 31414 790 00001
    VCID: 2C530083F69B
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans Labels: 09D-927-750.lbl
    Part No SW: 09D 927 750 FS HW: 09D 927 750 FS
    Component: AL 750 6A 1000
    Revision: 00H64000 Serial number:
    Coding: 0000504
    VCID: 84030823BE8B
    Address 03: ABS Brakes Labels: 4L0-910-517.lbl
    Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
    Component: ESP ALLRAD MK25E1 0130
    Revision: 00H22001
    Coding: 0038033
    VCID: 285BFC93E263
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601100625155
    Coding: 0000151
    VCID: E3C12BBF5BC5
    Part No: 4F0 910 131 G
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 335
    Component: FBSAUDIC6 KSG H27 0080
    Part No: 4F0 910 220 K
    Component: FBSAUDIC6 IDG H01 0060
    Address 06: Seat Mem. Pass Labels: None
    Part No SW: 4F0 910 760 HW: 4L0 959 760
    Component: Sitzmemory BFS H01 0100
    Revision: 00000000 Serial number: 00000000896401
    Coding: 0078944
    VCID: E1CD21B741D9
    1 Fault Found:
    01720 - Sensor for Seat-Back Recline; Pass. Seat (G279)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 133348 km
    Time Indication: 0
    Date: 2015.07.18
    Time: 04:05:50
    Address 07: Control Head
    Cannot be reached
    Address 08: Auto HVAC Labels: None
    Part No SW: 4L0 910 043 HW: 4L0 820 043 F
    Component: KLIMABETAETIGUNGH05 0060
    Revision: 00---012 Serial number: 00000030024523
    Coding: 0001046
    VCID: E1CD21B741D9
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0015121
    VCID: 306B14F3DAB3
    Part No: 4L2 910 113
    Component: Wischer AU716 H08 0080
    Coding: 00064792
    Shop #: WSC 31414
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150059
    Shop #: WSC 31414
    Address 0E: Media Player 1
    Cannot be reached
    Address 15: Airbags Labels: 4L0-910-655.lbl
    Part No SW: 4L0 910 655 B HW: 4L0 959 655
    Component: 30 AIRBAG AUDI8RH39 0120
    Revision: 06H39000 Serial number: 0037GD086JJ5
    Coding: 0013104
    VCID: 2C530083F69B
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H08 0230
    Revision: 00H08000 Serial number: 90054070070164
    Coding: 0112142
    VCID: E6C732ABA8F7
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H03 0030
    Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4L0 920 980 G
    Component: KOMBIINSTR. M73 H17 0120
    Revision: 00800000 Serial number: 5HJ39CH17
    Coding: 2657448
    Shop #: WSC 00588 067 57207
    VCID: 2341EBBF9B45
    Address 18: Aux. Heat Labels: None
    Part No SW: 4L0 910 105 HW: 4L0 815 071 D
    Component: Heizgeraet H08 0060
    Revision: 0000000A Serial number: 00000009014264
    Coding: 0000001
    VCID: E0CB24B34AD3
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 HW: 4L0 907 468
    Component: J533__Gateway H06 0040
    Revision: 00H06000 Serial number: 0900B07106829D
    Coding: F5DBFF7F303602
    Shop #: WSC 00588 210 91790
    VCID: ECD34083B61B
    Address 34: Level Control Labels: None
    Part No SW: 4L0 910 553 C HW: 4L0 907 553
    Component: LUFTFDR.-CDC H03 7660
    Revision: --H03001 Serial number: 15.1528-0096.2
    Coding: 0015510
    VCID: 2A5F069BFC6F
    Address 36: Seat Mem. Drvr Labels: None
    Component: Sitzmemory FS H01 0100
    Coding: 0074858
    Shop #: WSC 00551 210 91539
    VCID: E1CD21B741D9
    Address 37: Navigation
    Cannot be reached
    Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
    Component: TSG FA H12 0130
    Revision: 00-00000
    Coding: 0019163
    VCID: 2F69178FC78D
    Address 46: Central Conv. Labels: None
    Part No SW: 4L5 910 289 A HW: 4I0 907 28< A
    Component: Komfjrtgera`t H00 0020
    Revision: 0020 -(- Serial number: 04030362350000
    Coding: 7610619
    Shop #: WSC 96950 788 00001
    VCID: 33611BFF2BA5
    1 Fault Found:
    01134 - Alarm Horn (H12)
    009 - Open or Short to Ground
    Address 47: Sound System
    Cannot be reached
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 E
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000028039
    Coding: 0011101
    VCID: DEB71A4B70A7
    Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
    Component: TSG BF H12 0130
    Revision: 00-00000
    Coding: 0019163
    VCID: 2F69178FC78D
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000022
    VCID: 295DF997F969
    Part No: 7L6 941 329 A
    Component: AFS-Modul links H06 0002
    Component: AFS-Modul rechtsH06 0002
    Address 56: Radio
    Cannot be reached
    Address 57: TV Tuner
    Cannot be reached
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4L0 910 181 HW: 4L0 915 181
    Component: J0644 BEM H12 0530
    Revision: -------- Serial number: 00000000075285
    Shop #: WSC 00327 210 84725
    VCID: E4C328A35ECB
    Part No: 4F0 915 105 D
    Component: von VA0 2701152424
    Coding: 344630393135313035442056413032373031313532343234
    Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
    Component: TSG HL H21 0050
    Coding: 0018442
    VCID: 316D11F7D1B9
    Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
    Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
    Component: J772__Rearview 0050
    Revision: --H12--- Serial number: 525PA8-J6Z4102
    Coding: 1021001
    VCID: 2443E8A39E4B
    Address 6D: Trunk Elect. Labels: None
    Part No SW: 4L0 910 945 HW: 4L0 827 851 B
    Component: ValeoHeckdeckel H21 0280
    Revision: --H21001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    VCID: ECD34083B61B
    Part No: 4L0 910 946
    Address 6F: Centr. Conv. II Labels:
    VCID: 55A585678591
    Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
    Component: TSG HR H21 0050
    Coding: 0018442
    VCID: 316D11F7D1B9
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
    Component: Parkhilfe 8-Kan H12 0060
    Revision: 00H12000 Serial number: 06330700908350
    Coding: 0221146
    VCID: 285BFC93E263
    Address 77: Telephone
    Cannot be reached
    End ---------------------------------------------------------------------
