Mk2 TT Indicator Problem
AndyB-S3
Dundee
Hi guys,
Did a quick search but couldn't find (see) what I was after.
Basically when I indicate right the left flashes first then the right comes on shortly after. Is this a common fault or does anyone know if it's just a case of replacing the indicator stalk? Maybe a loose connection or worn? .
Car is a 2011 "60" plate. 40k miles.
Any help/advice would be appreciated. :)
Could be stalk or module at fault, ideally needs testing with replacement parts to eliminate things.
Does it have cruise as well?
Whereabouts are you located?
Hi, cheers for reply. Problem is irrelevant now..just bought a new car. Not because of faulty indicator tho..lol.
