Missing cover fixings.
Ianski68 Nov 2, 2018
  1. Ianski68
    Ianski68 Active Member Team Mauritius TDi Audi A4 Audi Cabriolet Owner Group S-line owners group Manual
    697
    133
    43
    So my wife had to call the AA out to our Audi A4 as the Turbo hose blew off! To get to it he jacked up the front drivers side and un screwed the fixings to the under panel and the bottom of the inner wheel arch so as to pull down the front Right side under panel. The problem is he never put them back!
    Does anyone know what they are called or even look like, also can I buy them from anywhere other than Audi or is a dealer job
  2. Avatar
    Google AdSense Advertisement
  3. Just Rob.
    Just Rob. Moderator Staff Member Moderator Regional Rep Team Brilliant Black Team Daytona TFSI Owners Group VCDS Map User Gold Supporter Audi A4 Audi Avant Owner Group quattro S-line owners group Manual
    8,994
    4,917
    ebay sell them, as do amazon etc, quarter turn fixings.
    I use DZUS ones with handle so easier to remove , but get the right size as length can vary and diameter, oem will be a lot more than aftermarket.
  4. Ianski68
    697
    133
    43
    Many thanks.
  5. Just Rob.
    8,994
    4,917
    you can get these kits very easy , has several of each fitting, undertray screws and wheel arch screw..etc
    just search webby for " Audi A4 B7 engine undertray fixing screws" .
    hope that helps.
  6. no_idea
    no_idea Well-Known Member
    436
    266
    Have you actually asked Audi the price, you might be pleasantly surprised!
    eBay parts are often more expensive.
    Sent from my Pixel 2 XL using Tapatalk
  7. Just Rob.
    8,994
    4,917
    I bought some from audi earlier this year and they were silly money for what they are, so after that I use Dzus fitting which are far better and free.
  8. kev-s
    kev-s Member
    85
    Id be calling the AA and complaining!
    He basically removed parts from your car then didn't bother to refit them and left your car in an unsafe condition
    I presume he didn't hand the fixings back to your wife and just took them with him?
  9. Just Rob.
    8,994
    4,917
    Possibly they weren't all there and may have been held in place by something else, in which case maybe that's why they weren't refitted .
    They are not difficult to use so not sure why the AA guy would have skipped refitting them.
  10. kev-s
    kev-s Member
    85
    Even if only a few were there to begin with whatever he removed he should of refitted
    He may of put them down in the back of his van and forgotten about them
    Even if there had been something else used instead i would expect the AA man to make the under tray and arch liner secure or at least explain why he hasn't refitted the fixings
    Imagine if you drove down the road and the arch liner or under tray caught something or came away causing an accident/damage to the car
    Id definatley be speaking to the AA to complain and see if they will supply and fit new fixings
  11. piglet14
    piglet14 Finally got my midlife crisis car
    132
    13
    I bought screw part No. 8D0805121 which are correct for mine. eBay item number: 202346116899 (Hong Kong 2 quid!)
    But then found that the clips were part of the problem so bought them as well, eBay item number: 222862151492 (UK 4 quid)
    Slightly confused though as the clips seem to have the same part No. as the screws.
    Clips still in glove box at the moment!
