Memory Seats Retrofit - A5/S5 SPORTBACK
DarkyUK
Dave is correct, no CP on the seat controllers and I believe also that mid line should be fine, I think I only needed high line for the side assist and even then it was for the warning lights within the doors, the exit assist, not the side assist itself
strandgaard
Hi Dave
I got everything wired up today, but i am having trouble finding the correct coding.
I made these adaptations to 5F:
Car_Function_List_BAP_Gen2:
LO] _driver_seat_0x10: [VN] _activated
[LO] _driver_seat_0x10_msg_bus: [VO] _CAB_4
Car_Function_Adaptations_Gen2:
[LO] _menu_display_seat_configuration: [VN] _activated
[LO] _menu_display_seat_configuration_clamp_15_off: [VN] _not_activated
[LO] _menu_display_seat_configuration_over_threshold_high: [VN] _activated
[LO] _menu_display_seat_configuration_standstill: [VN] _not_activated
[LO] _menu_display_seat_configuration_after_disclaimer: [VN] _not_activated
The Driver's seat memory is present on MMI but only "Store setting on memory control key" present.
You mentioned the following coding:
Seat control unit drivers side 36
Byte 2 bit 0-1 This is MMI part (This should now make easy entry work) - this is not documented i my controller
Long coding p_button_memory This is to turn on switch. - Done- Byte 2 bit 1
Long coding p_button_location change to internal This activates memory part of switch. Done - Byte 7 bit 0. It was set to External
Long coding acoustic_feedback_if_stored This makes it Beep when you store each position. Done - Byte 1 bit 3
So everything should be right, but nothing happens when I press the buttons in the door
Any ideas?
strandgaard
Yes - that brought up the drivers seat menu.
I suspect the wires going to pins 17 and 19 in the door controller may be crossed. I will check tomorrow.
strandgaard
I just pulled the doorcard again, and all wires are mounted correctly.
I'm really hoping that somebody can help.
What puzzles me the most is that "p_button_location" should be set to "internal" in the seat controller, as the memory switches are in fact mounted externally on the door controller, and the seat controller pulls the switch settings via CAN.
And it was indeed set to "external" when I mounted the controller.
Any help would be appreciated.
strandgaard
No.
I am also following a thread on the german Motor-Talk forum, where a guy mentions that the seat controller will need CP unlocking, and that memory will not work before this has been carried out.
But I just can't see any component protection with my VCDS V2 cable.
strandgaard
Hi,
I managed to get it to work yesterday.
I needed to code the door controller to use memory mirror to make it work. And i don't even have memory mirrors....
So it works with mid-line door controllers and the memory controller don't have component protection.
Thanks for your help.
Rybo vw cc
Anyone have the wiring schematic and pin outs for a set of B8 S5 Recaros? installing these in my 2010 VW CC and swapping wiring harnesses from my stock seats to allow the plugs to match up. Just looking to ensure I am wiring the pins correctly, especially for the heated seat component so i don't light my *** on fire :D
Rybo vw cc
Or if someone wants to shoot me a 2010 (B8) S5 vin number in my Inbox, I can go to the Audi dealer and get a wiring layout from them direct. Thanks for your help.
zzattack
Question for strandgaard as he fitted this on an A4, or maybe andyhud or DarkyUK know too..
I'm trying to install the controller underneath the seat but this appears to be incredibly tough for me. I started in the door and fitted the switch + wiring there with no issue, but the seat is proving to be tough. After over 30 minutes of fiddling I haven't been able to even fit the retainer bracket for the controller, and I do have an EKTA picture showing where it's supposed to go. Probably wrong bracket, I guess, but that's something I can overcome.
What I need some help with is installing the new cable loom underneath the seat. I've looked at every connector and only a single one actually mates to one of the connectors in my replacement loom. Do I need to disassemble much more of the seat to reveal further connectors? How much of the original loom should be removed? Did anyone who has already performed this retrofit take any pictures of it? I'd be much obliged!
strandgaard
Hi zzattack.
Sorry, but i can't help you with that question.
I swapped the entire seat to a seat with the correct wiring loom and memory controller already mounted.
If you are skilled in russian, here is a description of the operation, you are working on: https://www.drive2.ru/l/498699717648056630/
All I did was run extra 12V and ground wires and the Comfort CAN-Bus wires.
zzattack
Thanks for that link, pictured look daunting.. but not too informative just yet, I can't decipher if he moved the padding over onto his original frame and replaced most of the loom, or if taking out all that padding isn't necessary in my case.Guess I'll take out the seats when I've got a full weekend to spend on it.
zzattack
Ok, massive updates on my end. The aliexpress package indeed came with wrong wiring harnesses, so not too surprising that I couldn't make any sense of it. I got the correct parts from the stealers using the part numbers from the Russian blog that @stramdgaard linked. The wiring job itself wasn't even bad at all, took maybe 2 hours including taking the seats out and reinstalling.
With everything in place, coding was straight forward. At least for the driver side, that is. I repeated the same on the passenger side and coding was a tad more involved, but I got it to work eventually. Might be a first, I haven't come across passenger side memory seats in A4/A5 yet, but given that it's available for Q7 and the platform is mostly shared I figured it'd be a good challenge.
Even the easy-entry works at passenger side, but I have one question about this: if this is available in the A5, do you also have the MMI menu option to disable it (passenger side)? I can only get the menu item to appear for the driver side, which seems odd.
Lizard821000
Can anyone confirm for me that you can essentially take any fully electric seat and make it a memory one with the right bits? Or does the memory seat have different motors in them with small modules on for the function to work !?
obviously there’s more to it but is that the black and white of it , making a standard full leccy seat into a memory one without needing to have an already memory seat Cradle and motors
Adam14
In a B9 car it needs a module underneath the seat which most coupes have to begin with (but not always). Electric seats in a sportback rarely have this module.
So the answer is yes but no as well. That is my understanding and as a result of research, as getting the retrofit done in a couple weeks.
Sent from my HD1913 using Tapatalk
Lizard821000
Mine is an avant , but I’m reading conflicting info online wether the motors on the memory seats have sensors for positions or wether any leccy seats will work if you just swop over the seat harness and module,
Iv done the conversion but had to swop over skins from seats or believed I did to get them working as the motors differed , now I’m finding out MAYBE it’s just the harness and module to swop out and the motors will work from that alone
zzattack
Literally just swop over the modules for a memory one !?
No, there won't be a module if there's no memory for the seats yet.
You need to fit the control module and replace the wiring in the seat. Module is about $150 (aliexpress, new, OEM) and wiring is about €100 (at the dealers). After that you need to connect the extended canbus to the memory seat controller, which is just 2 wires. Can be done in about 2-3 hours.
Lizard821000
So full
Leccy seats don’t have a module? No black box under the seat
