Hi Guys
Sorry if you have seen this in the B7 areas but i've been working on this retrofit for a few weeks and I just cant seem to get it working. I followed much of the DIY 1 and 2 from the Audizine forum plus a few other versions on other forums.
I also have a wire diagram attached below.
So this is what I have
Memory Switch T10 T32 (window regulator)
1-----------------------------19
2-----------------------------15
3-----------------------------Brown (lock)
4-----------------------------17
5-----------------------------18
6-----------------------------Blue/Brown (lock)
7-----------------------------16
8-----------------------------31
9-----------------------------14
10----------------------------30
Red T10 under seat T20 A-Pillar
6(or/grn)-------------------------20
7(or/brn)-------------------------3
10(gr/blk)------------------------4------------------------to pin 10 (Black T10 of window regulator)
I didn't have a green/black wire continuing from the other side of the T20 A-Pillar connector (Pin 4 as above) to the door card window regulator, so i've added a repair wire from T20 pin 4, through the door hinge bellows, to pin 10 of the black T10 of the window regulator.
My memory switch buttons lights up, but it still wont move the seats.
Questions I have
1) My Red T10 under the seat does not currently have a connection wire in the top of the plug (Pin 10) its just empty. Does anyone have information on whether there is supposed to be a wire from there going somewhere? I presume there should be one (maybe to a connector under the seat) otherwise the green/black wire travelling to the T20 A-Pillar pin 4 has no signal to carry.
2) Does anyone know of any other reason why this wouldn't be working by now? Any more connections to make? VCDS to code?
Thanks for any help.
Questions I have
