Cheeks
- Joined
- Feb 13, 2015
- Messages
- 287
- Reaction score
- 9
- Points
- 18
I've replaced my master cylinder with one from a breaker yard because the pedal was slowly falling when applying brakes.
On to the replacement...
Fitted okay, bench bled, seemed okay.
Bleeding
Calipers
front left and back right had pressure on each press.
Front right and back left seemed to dribble when pressing and suck back just as much.
Master cylinder
Rear bleed screw (nearest to booster) pressure on every push
Front bleed screw (furthest away from booster)
Same as calipers small amount out sucking air back in
Also the fluid level goes up with the pedal down and goes down with the pedal up, don't know if it's meant to do that or not.
Need to fix ASAP anyone got any ideas?
Bleeding
Calipers
Master cylinder
