bonecore
- Joined
- Jan 1, 2017
- Messages
- 85
- Reaction score
- 6
- Points
- 8
1)If the clutch is pressed all the way in or depressed all the way out you are not producing wear and tear on the clutch.Only at times when the clutch is partially pressed .. those are the times that produce wear and tear.
2)Having max torque 300Nm vs having max torque 350Nm and only flooring it if clutch is depressed all the way out... makes little to no difference in clutch wear
3)Reving it and poping the clutch very fast or riding with clutch partially pressed causes high wear and tear on the clutch.
4)flooring it in 2nd gear(no clutch) gives more wear than flooring it in 6th gear(no clutch)
5)flooring it below 40mph gives more wear than flooring it above 40mph
6)having exact torque=300Nm between 1500 to 5000 rpm. Same gear, clutch depressed ... flooring it at lower rpm=2000 rpm gives less wear than flooring it at 4000 rpm.
7)perfect revmatching gives very little wear on the clutch
8)having a quattro gives more wear on the clutch than having 2WheelDrive
ty
ty
