maf readings to bhp conversion
djdougalno1
hi anyone know how to do the conversion from maf readings to bhp cheers
to convert MAF readings into approximate BHP figures divide the g/s value by 0.8, or multiply is by 1.25, both give the same result.
120 g/s divided by 0.8 gives 150bhp for a standard A3. 160g/s or there abouts for a mapped A3
168 g/s divided by 0.8 gives 210 bhp for a standard S3. 200g/s or there abouts for a mapped S3
You usually won't see those exact figures of course, but that's the ball park you're after
1.25
When my car was down on a bit of power and done a couple dyno runs on my liquid gauge i was getting 258bhp. My air readings were 208g/s. 208 x 1.25 = 260. So not far off really!
when do you collect the G/S value, will it increse and decrese ad you put your foot down, at which point do you take the figure??,
I have been speaking to my mechanic (as in one of my threads i cant decide if my car is mapped or not) and he said he thinks he has some software that can measure this. I can probably use this to work out if it is mapped or not
if logging, look at 115 and 003 and you will see what boost (unless its an agu) and what airflow.
std 150bhp airflow is 120g/s, 210/225bhp is 180g/s as a guide
I still need to buy the VCDS upgrade... You can't log half the required blocks with just the lite version :(
Thanks, my mechanic has a scanner, not VAG COM so we will have to see if it gives MAF reedings and btw mine is AGU
You can do the air flow logging though dude. Doesn't the shareware give you up to block 025?
Anyway, either /0.8 or x1.25 your g/s figure gives an estimated BHP output.
1.25
I'm fairly sure the liquid gauge uses airflow to calculate bhp anyway, so no wonder they were similar numbers!
Scanners don't normally do logging mate, they tend to just read/clear fault codes...
he said his scanner offers Live Data, we are going for i spin tomorrow to get the figures, i havent told him the full extent of the test lol, he doesnt know we will be at the redline in third lol,
is it the peak figure i am looking for???
Yep, take the max g/s value from a run up to the redline.
motorway juction should be fine to do ur "77mph" lol if ur lucky enough to be close.
i have a m1 junction 13-14 running accross the backend of milton keynes so thats a good place for me
The limiting factor in top speed is power not gear ratios. In theory, if you could get to 7200rpm in 5th gear you'd be doing about 180mph, but the power simply isn't there.
I managed to get my stage 2 agu to 6600rpm in top on the kerpen autobahn, which was 163 according to the satnav
I think you are referring to the 5 speed box to get 100mph out of 3rd. the 6 speed is a lot shorter ratio, good speed there but what was it showing on the dash? I bet over 165! I was once in a fully stripped A3 with K04 that reached way below the clock. if only the head permitted, there was still tones of torque coming from the engine which I think would have taken it over 170mph
easier said than done..
IHI'd back in 2003, 320bhp, seat ibiza @ bruntingthorpe 2 mile straight, 160mph was its gps timed Vmax. speedo was off the clock.
I did a Vmax day with pistonheads back then, and what a crack it was.. ickle seat ibiza going side by side and head to head with proper fast cars, and M3, M5's loosing in a rolling start and slower terminal.. funny as :)
Cos I bet that didn't make you smile at all..... Much. :thumbsup:
I was indeed refering to the A3 5 speed box, as DannyH who asked the question has a 150bhp 5 speed A3 :)
Speedo on the A3 was well off the clock on 6600rpm, showing roughly 170 indicated speed, 163 on the satnav
Weel guys i wen out last night and got my data.
firstly whe i was driving the G/S value incresed when i let of the accelarator,
well i diddnt hit 7500 but i took it to 7000 in third and i recorded 127.5g/s
so..
117.5 x 1.25 = 146.88 so 147bhp
is this normal, i am guessing so
however when i let off to change gear i recorded 124g/s
why does it increse when i let off.
any way conclusion..... Remap Time
that airflow matches cars which I see and dyno at around 150bhp, so looks normal for stock car
Remap time now then :)
10
857
728
958
