Lowering springs
Andros4
Hi people been thinking of lowering my s4. It’s bugging me it’s just a bit to high. Was wondering if anyone has done it and what springs they used.
And
Is it easy to do. Do u need anything other then springs to fit
V6_Man
Moderator
Staff member
Moderator
WesT-gefül
Well-Known Member
Bronze Supporter
If you’re going to use anything use Eibach springs. Just remember if you’re going lower than 30mm, you are going to alter your geometry. If you have the car with the lowered suspension which is 20mm drop found with b9’s that have a sport suspension.
So for eg if you have a sports suspension and buy the Eibach pro kit which is 30mm from a standard setup the overall drop will be 10mm because the sports suspension is already a 20mm drop.
Eibach also do a Sports line set of springs with a larger drop. I’m not sure what the drop is for the b9 but you can find out. From other cars it’s around 50mm +- with different drops front to back. Eg 40mm 50mm
This will inevitably harden your ride especially with 19” and the lower ride.
Andros4
Been looking at raceline they lower car up to 25mm
WesT-gefül
Well-Known Member
Bronze Supporter
Is the brand called raceline? So they are quoted as 45mm? I assume your car has the sports suspension with a 20mm drop already. One thing I like about Eibach is they test their springs on the car and the quality of the springs. Cheap springs rust out with the salt we have. Next in line would be H&R.
Daggerit
In terms of installation, because the front setup is a multi-link system with infamously difficult-to-remove pinch bolts, it's not something that I'd want to do myself. The rears are significantly easier but you'll need a spring compressor for them unless you're taking a lot of the rear apart. Also as a result of the setup it's quite easy to alter the geometry by accident so I'd definitely recommend an alignment after fitting. :)
SMI77
Australia
Definitely what he said...
SMI77
Australia
Have both, with suspension set on comfort & all others on dynamic and find the ride actually better. That was P Zeros. Now on PS4S., but find those tyres firmer, but prepared to put up with that.
WesT-gefül
Well-Known Member
Bronze Supporter
Can you remember the load rating of the two tyres? This could be the reason. I like higher loads that what the car specifies because it helps reduce the tyre deforming in corners which makes it feel firmer and more planted.
SMI77
Australia
No, not specifically.
