Low top end power after 3000rpm no fault codes?
UK88
Hi All,
I'm struggling to figure out why my Audi A3 2.0 TDI 2006 140bhp (147k) is lacking power after 2500rpm.
1. I have no fault codes registered.
2. Taken for diagnosis, including test drive which showed no issues at all with boosting, however I feel like the car isn't even boosting after 2500rpm; just runs out of steam, and requires a gear change to keep accelerating.
3. I've changed the turbo, egr, maf and injectors (used 73k ones) with no major difference.
4. Fuel economy is down from 40-58mpg to 25-38mpg. Car is not smoking either.
The car idles and drives fine as long as I don't exceed 3000rpm which feels like its peak point for a gear change.
I suspect after everything changed it could be a weak fuel pump, tandem pump, restriction or the boost control solenoid block.
Has anyone experienced this before? Please do share your symptoms for any of the possible issues above so I can get a rough idea of what I could be. Thanks :)
UK88
Yep, made no difference at all. Running out of ideas now. It’s even more frustrating to keep going to different mechanics and being told nothing’s wrong with it.
Audia31992
Hi All,
Hi there having the same issue here did you find out what was wrong with it
samuelh_888
Is it doing it’s regen or is the dpf blocked?
UK88
Hi, unfortunately I haven't, just continued driving it as no faults have flagged up. Most likely will take it on a dyno/remap to see what its current power output is in comparison to stock.
