I've been getting pretty bad clicking/ticking noise coming from I think rear of the suspensions.. It's present at all speed but you can only really hear it inside a garage with windows down and especially bad when doing faster turns low speed. Doesn't sound like CV joints, nor wheel bearings as it's not really rpm dependent? Anyone had the same and identified the issue?
Have you looked under the car? Something hanging down that's touching the wheels sometimes. I had that once (on a different car).
As @Wibbly says check under the car. Possible issues with heat shields bent touching the exhaust or if not that check the exhaust valves and see if they are failing. Another issue is with the brake dust shields rusting, it's possible they have bent and are touching the discs??? All guesswork really. Let us know if you manage to sort it.
