Loud speaker/bluetooth issue (Fault codes present) S3 8P
RosscoJr
Recently purchase an S3 8P with all sat nav, ICE upgrades and have developed a problem. Had a loud high pitched noise come from the speaker system some weeks ago & couldn't stop it, eventually it did of own accord.
What i have been left with is an issue with bluetooth or the voice control system where by my phone will connect but keep dropping out and no sound coming through speaker system (when i press voice control button on steering wheel it mutes sound but again nothing from speaker system).
Had the car plugged into VCDS which gave the following info:
Thursday,07,May,2015,17:32:02:46332
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
www.Ross-Tech.com
VIN: WAUZZZ8P67A225902 License Plate:
Mileage: 110090km-68406mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 76 77
VIN: WAUZZZ8P67A225902 Mileage: 110090km-68406miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0050
Revision: 5BH16--- Serial number: AUX7Z0G4FN4096
Coding: 01030003180F0060
Shop #: WSC 06314 000 00000
VCID: 377B4D9C46F978999F5-8062
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
VCID: 72EDBC886D1BDDB168B-8027
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AD HW: 8P0 820 043 AD
Component: KlimavollautomatH19 0360
Revision: 079226 Serial number: 8P0820043AD
Shop #: WSC 00000 000 00000
VCID: 6ED5A8F87923F9518C3-803B
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000007079919
Coding: F18E5F07A014100000000000000000000008EE175A0500
Shop #: WSC 06314 000 08192
VCID: 4089264013373F212EF-8015
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H13 4220
Revision: 91H13422 Serial number: 0037W0G1L3YV
Coding: 0070612
VCID: 479B3D5C36190819EF5-8012
Subsystem 1 - Serial number: 63328RB4026ABE56W
Subsystem 2 - Serial number: 63428RB4026979DD
Subsystem 3 - Serial number: 63528RB4026ABEB7+
Subsystem 4 - Serial number: 63628RB402697A0AP
Subsystem 5 - Serial number: 63729RB4027CD411N
Subsystem 6 - Serial number: 63829RB4027CDADFD
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
VCID: 418F2344183D3629211-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 J HW: 8P0 920 981 J
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 2244G004003464
Coding: 0005418
Shop #: WSC 63351 210 01865
VCID: 3F8B25BC6EC940D9575-806A
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 330010742607A6
Coding: FD0F07C807000101
VCID: 2F6B75FCBEA9B059C75-807A
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 3665409841F38191843-8063
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20004 Serial number: AUX7Z0G4FN4096
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
Component: RNS-E HIGH EU H73 0600
Revision: 03S Serial number: AUZBZ7G0907389
Coding: 0209717
VCID: 38794EA04BE777E196F-806D
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 16
Reset counter: 10
Mileage: 101253 km
Time Indication: 0
Date: 2014.12.03
Time: 03:49:55
Freeze Frame:
Voltage: 10.60 V
Mileage: 110080 km
Count: 705
Clock: 17:13
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000560
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.150 H07 1806
Shop #: WSC 02069 000 90108
VCID: 356747945CF58A898D9-8060
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H05 0070
Coding: 9980202002186D298505489AC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000560
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
012 - Electrical Fault in Circuit - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3D775FB464C552C9459-8068
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209717
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Reset counter: 10
Mileage: 101253 km
Time Indication: 0
Date: 2014.12.03
Time: 03:49:55
Freeze Frame:
Voltage: 10.60 V
Mileage: 110080 km
Count: 705
Clock: 17:13
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 00067824830712
Coding: 0000113
Shop #: WSC 131071 1023 2097151
VCID: 3C7152B07FDF5BC1727-8069
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 22
Reset counter: 9
Mileage: 87764 km
Time Indication: 0
Date: 2013.09.16
Time: 19:20:55
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 K
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005138383
Coding: 0011422
Shop #: WSC 00515 210 91544
VCID: 44812A50072F23010A7-8011
End-------------------------(Elapsed Time: 02:07)--------------------------
I know about parking sensor issue & door locks are ok now i did have problem with passenger door that i noticed once. What worries me is the voltage fault codes, does any know anymore?
Thanks in advance.
