Loose connectors under drivers side door panel ?
jetty
I have noticed an annoying knocking noise coming from the door panel - removed it today and found 3 disconnected/loose connectors under there.
What are these for / should they be disconnected ? Seems odd to have some connecting flapping around under there!
B5NUT
Well-Known Member
Someone has been messing around as that black shiny tape should not be there, as Audi never use that stuff. Also Audi never leave extra plugs on a car, the wring harness is specific to the options fitted to your car. My guess is that someone for some reason has swapped either the door including the harness, or the harness has been swapped out for a retrofit that has been removed.
jetty
Thanks B5 - I suspect the door has been changed. Will be an interesting convo with the audi dealership next week!
