Looking at buying an 8L
Sean Gaffney Jul 13, 2018
  1. Sean Gaffney
    Sean Gaffney New Member
    9
    Hi guys,
    Looking into buying a 8l S3.
    Just wanting advice on anything to look out for when buying. Particularly engine/quattro wise.
    I have found one I like online and I'm going to see it...
    I have been told it has small blisters on the rear arches, is this a common problem for them? And is it a lot if any hassle to have repaired.
    Any help would be greatly appreciated
  2. Avatar
    Google AdSense Advertisement
  3. antwan64og
    antwan64og Well-Known Member
    1,036
    272
    The cars are a minimum of 14 years old, bubbling arches are minor concerns.
    The shell and motor itself are the most solid parts, most everything else will have been replaced.
    Sean Gaffney likes this.
  4. Mav190sline
    Mav190sline Active Member
    215
    31
  5. Stuart B
    Stuart B Well-Known Member
    3,448
    739
    Be prepared to consider more than blistering arches, most S3s are money pits. If some paint bubbling is the main focus of issues then you have found a gem.
  6. S3AMJ
    S3AMJ OEM+ Team Brilliant Black Audi S3
    1,173
    321
    Anything that’s rubber.... is something to consider changing if they haven’t already, hoses, bushes, etc. These cars are getting to that age now. These are things I’ve been going about replacing recently. For pure love of the car, wouldn’t have anything else. I was driving behind one today around Slough, they stand out from all these new cars. A future classic in my eyes
  7. S3JACKSON
    S3JACKSON Active Member
    144
    78
    Have a good read of the buyers guide as it covers most things you will need to know.
    They are great cars and it's nice having something different, being a mechanic which a lot of owners i meet are helps!
    S3AMJ likes this.
  8. Stuart B
    3,448
    739
    Hehe those owners usually have another job and had to become a mechanic for day to day repairs.
  9. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    2,645
    695
    Scan if for fault codes if you can if not see it it wheel spins to test the Quattro, engine and turbo play not much you can do on a test drive I doubt they will do a compression test
    Also see if they will throw in some axle stands ,
    Just look out for the usual things when buying a car and make sure you have money put aside(seriously)
    S3AMJ and S3JACKSON like this.
  10. antwan64og
    1,036
    272
    Haha, the truth.
    We learn to weld broken clutch pedals by necessity, fit window mechanisms and bushes as needed and when a clutch replacement is the cost of the vehicle you do it yourself.
    Prawn and Tuffty just took it one step further :whistle2:
    andrew_wright and S3AMJ like this.
  11. S3JACKSON
    144
    78
    Having Tuffty on here is a Godsend:sunglasses:
    S3AMJ, Jeriho and andrew_wright like this.
  12. Avatar
  13. JonnyDerv
    JonnyDerv Active Member
    692
    136
    43
    Cannot stress enough how setting money aside is important.
    Tj 0785 and S3AMJ like this.
  14. RS4B5
    RS4B5 5 pots
    536
    210
    43
    Not a single spot of rust on mine but it isn't a s3
  15. S3 ROCKS
    S3 ROCKS steve
    250
    17
    The stickie covers the majority of common issues. If it has a history then definitely check through receipts for big replacements such as Clutch and flywheel and on the test drive interrogate the 4WD. There shouldn;t be any wheel spinning or torque steer.
    Good luck if you don;t like it mine will be up for sale once I find my next car I'm after
