  2. Dismiss Notice
Long time rebuilding engine means I've forgotten a few bits....
Graham Smith May 8, 2020
  1. Graham Smith
    Graham Smith Member VCDS Map User
    64
    Hi All,
    Long story short, I blew my engine with stage 3 map (Revo) up a while ago. Work, moving house and other odds and sods meant I asked a mate to remove the old engine while I set up the new one. Anyhow, it is now pretty much one large mechanical jigsaw and as I didn't take it apart, I'm having trouble putting everything back together - especially as he seems to have "Lost" a few bits.
    First question is this - On the Turbo there is a take off pipe (about 10mm - Pictured). Am I assuming that this goes to the top of the rocker cover (Two pipes, one about 25mm, the other approx 10mm).
    Then there is the Aircon hoses. If anyone has a diagram of just how these fit, that would be fantastic. The problem I have is that one of the hoses (from the bulkhead, going into the cabin - the larger of the two hoses; does this hose fit to the compressor or to the Aircon Rad on the intercooler / radiator assembly?) just doesn't want to fit anywhere. I then have two other connections (total 3 connections) but can only find 2 x places for them.
    Thanks Guys, any help much apreciated.
  2. Avatar
    snack-media
    Advertisement
  3. Daveyonthemove
    Daveyonthemove Well-Known Member VCDS Map User
    1,828
    624
    What engine is it?
  4. Graham Smith
    64
    2.0 TFSI - Original is (was) a BWA, replacing with an AXX until I get the other one sorted (Oil pump packed up).
