Leaking oil 2.0 tdi bmn engine
bradh
Active Member
hi guys I’m back in a tdi now not Audi but Skoda Octavia vrs tdi mk2 iv got a few little niggeling oil leak on my engine, 1st one was a broken return pipe witch showered back on engine in oil that’s fixed then I had gasket fail on the fuel pump mixing with oil leaking all down side of engine and gear box and now iv found another it’s behind the inlet manifold , I replaced the orange gasket with a new one on Saturday was leak free until today :( it’s now leaking again down the front of the block just like before , has anyone come across this leak before if so how did you fix it tempts to fit the mental inlet manifold from the BKD engine and hope this fixes the issue but thought I’d ask up on hear 1st in case there’s another fix
EXSpartan36
Active Member
Have you checked that all the breather pipes on the engine are clear and not blocked? if you have a pressure build up in the crank case it'll keep popping seals.
bradh
Active Member
Sorry for delayed reply no I haven’t witch ones should I check ??
Cheers brad
Lee3011
Did you get this sorted?? I’m having the same issue and I’ve also recently fitted the bkd manifold but if anything it’s gotten worse
bradh
Active Member
Hi yes fixed it this week end by fitting the bdk manifold as it was leaking from the flaps in the plastic manifold, Ware does your start to leak from middle or one end, could be the fuel pump on the end of the head that's seal has gone causing the diesel and oil to leak a cross the head
Sent from my G8141 using Tapatalk
Lee3011
It’s leaking in the middle, it’s definitely oil and not diesel
bradh
Active Member
Witch gasket did you fit looked like you brought the darksidedevelopments.co.uk conversion so should of had the metal gasket
Lee3011
Yes mate darkside fitted it with the metal gasket, I’m thinking it’s the oily crap out of the egr system that’s seeping out, it was like this before the conversion, I’m not loosing oil as the dipstick is bang on and so is the water
bradh
Active Member
Yes mate darkside fitted it with the metal gasket, I’m thinking it’s the oily **** out of the egr system that’s seeping out, it was like this before the conversion, I’m not loosing oil as the dipstick is bang on and so is the water
Yea could be take off the egr valve and clean it got mine spotless as it was about 5/7mm thick with crud
Lee3011
I’m going to darkside to have the egr delete kit fitted then see how it is mate cheers for your input
