Hi everyone. I own a 2012 Audi A3 1.6 TDI, engine code CAYC. I noticed strong diesel smell coming from an engine compartment a couple of weeks ago. I removed the engine cover and saw that the second fuel injector is wet in comparison all other injectors. I asked a mechanic to check it out. He cleaned an area around injector and I started the engine, first idle, then gave more revs. The mechanic said it leaked from under the big nut that was located on top of the injector, please view the image below (look at the yellow arrow). Can it leak from there? Is there any sill under that nut that can/should be replaced instead of replacing the whole injector? Can it leak from another place, for example from a fuel pipe connection and make it seen as it leaks from the injector itself?
Thanks for advise.
Thanks for advise.
